Prius Prime Battery Replacement
Discussion in 'Prime Fuel Economy & EV Range' started by ClemsonSteve, Apr 6, 2021.
  1. ClemsonSteve
    ClemsonSteve Active Member
    270
    248
    South Carolina
    Do we know of any regular use (and not a manufacture defect) battery failure and subsequent replacement in a Prius Prime? And if so, the cost? And yes, it would have to be a high mileage car--as the warranty in most states is 100,000 miles.
    49,490
    not that i have read, but there are probably numerous salvage packs by now.
    and btw, toyotas warranty covers the battery regardless of defect. you just need a code
  3. ClemsonSteve
    270
    248
    South Carolina
    Sure, but that ends after 100,000 miles, correct?
    49,490
    yes, if you are not in a carb state. but double check your warranty manual, i thought i read toyota was going 10/150 across the board for the battery
    Aaron Vitolins and Celliott1778 like this.
  5. ClemsonSteve
    270
    248
    South Carolina
    Yes--I think they did too--but not for the 2017....
  6. bisco
    49,490
    you're probably righ. i would say the odds of your battery going bad are miniscule.
    i'm not sure we've even had one on the pip yet
  7. ClemsonSteve
    270
    248
    South Carolina
    You hear stuff about "battery degradation" and the like--stories that make someone think they won't last for the really long haul. I'm just curious if any have actually failed...
  8. bisco
    49,490
    right. degradation is minimal butallbatteries degrade to some extent.
    failure is extremely uncommon, if at all. toyota builds these drive trains rock solid
    Unresolved_ERR and ClemsonSteve like this.
  9. ozmatt
    ozmatt Active Member
    604
    251
    australia
    This will be interesting, I have been wondering the same! early failures of nimh packs in regular hybrids is not often seen before about the 5 year mark, and most that fail early are cabs...
  10. ClemsonSteve
    270
    248
    South Carolina
    Well I can say this--I'm gonna find out just how far it will go--God willing, but it could outlast me LOL.
  11. pghyndman
    pghyndman Active Member
    498
    465
    CT shoreline
  12. ClemsonSteve
    270
    248
    South Carolina
    Sure, but for 2017 in most states it is only 100,000 miles....
  13. Salamander_King
    Salamander_King Senior Member
    10,975
    8,867
    New England
    This thread will help you answer your question: Does anyone know how much a full battery replacement for the Prius prime would cost ? | PriusChat
    I think the battery degradation is more closely correlated to the age of the battery than the miles driven. If you have a 4 years old 2017 PP and driven over 100,000 miles already, how much of that is actually on EV mode? I am sure the charge cycle is much less than say, a PP driven for 10 years but only 25 miles/day all on EV mode with daily charging. (25milesx365daysx10years=91250miles)
  14. bisco
    49,490
    i have 55,000 miles of ev on my 9 year old pip, plus whatever battery use on another 20,000 miles of hv.
    i'm still at 85% of new, and lost most of that in the first year or two.
    i'm sure toyota made some big improvements by 2017.
  15. ClemsonSteve
    270
    248
    South Carolina
    Great point!
  16. Celliott1778
    Celliott1778 Junior Member
    Hampton Roads, VA
    Just bought a 2021 and can confirm the warranty on battery is 10 year/150,000 miles. Traded in 2014 Prius C which had 100,000 mile warranty on the battery. That car had 155,000 miles and no issues.
    bisco and ClemsonSteve like this.
  17. ClemsonSteve
    270
    248
    South Carolina
    You are correct. And I hope you get 200k or more out of this one!
  18. Henrik Helmers
    Henrik Helmers Active Member
    100
    148
    Norway
    2020 Prius PHV
    I own a couple of Apple devices that I charge every day, sometimes multiple times a day. And despite poor battery management they have survived years and years of use. I have yet to have a device in active use (not just stored with an empty battery) fail.
    With the large buffer in the Prius Plug-in, I am not sure you could reach the similar usage levels—even if you did charge it twice a day.
    Are there reports of Primes (or even the old Plug-in) "using up" the battery?
    jerrymildred likes this.
  19. jerrymildred
    jerrymildred Senior Member
    11,511
    14,113
    Tampa, FL
    Just to clarify, the warranty on NEW Primes and other Prii is 10/150. Toyota did not make that warranty backward applicable to previous years. So the warranty info in someone's 2021 will not apply to someone else's 2017 unless that 2017 is in a CARB state.
    I have so far never read of a Prime's battery failing. I have read tons and tons of complaints of range reduction, but range reduction is not the measure of battery health. Battery health is best measured by how many kWh it takes to charge it. Mine is still the same as when I got it two years ago, and according to the eco history of the car, the original owner almost never charged it.
    Henrik Helmers likes this.
  20. r3dDaWn
    r3dDaWn Junior Member
    Four Touring
    I know the cost of not covered by warranty is around $3100-$3500, if you go though Toyota/dealership. A co-worker had a 2017 that had battery fail and his cost was in that range.
    ClemsonSteve likes this.
