Prius Prime chassis
Discussion in 'Prime Main Forum (2017-2022)' started by tonypalermo, Apr 14, 2021.
  1. tonypalermo
    tonypalermo Junior Member
    17
    Sacramento
    2018 Prius c
    I've noticed every time I start driving it sounds like the chassis or the undercarriage is making sounds or moving. When I start driving it's almost like it moves a little or flexes. It's a very strange sound. I don't know how this is possible maybe it's not even the chassis that's doing it but Toyota says it's a normal sound. Has anyone else heard any sounds when you start driving. Normally the car has to have been sitting for awhile or normally when I first start driving it.
  2. schja01
    schja01 Senior Member
    1,862
    1,234
    Chicagoland
    2024 Prius
    Limited AWD-e
    ABS calibration?
  3. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    Our '16 Three Touring clicks and clacks when turning the steering wheel and touching the brakes during the first movement of the day. I consider it all normal.
  4. Mendel Leisk
    42,149
    By “Toyota” I presume you mean a dealership? They test drove? Try another dealership if possible?
    This might be problematic, for dealership diagnosis.
  5. tonypalermo
    17
    Sacramento
    2018 Prius c
    I will check into this, thanks for the advice. I did not even think about that.
  6. tonypalermo
    17
    Sacramento
    2018 Prius c
    Yes a dealership I can try another one for sure.
  7. tonypalermo
    17
    Sacramento
    2018 Prius c
    Yes it could be normal but I want to make sure. If it is normal I feel pretty stupid about it.
  8. Trollbait
    12,776
    Hard to tell without knowing what the sound actually is or where it comes from. Could be the brakes. Could be the suspension settled down while parked.
    If normal, the technician should have been able to name what it was. Of course, that info may have been left off by who you talked to behind the desk.
    Reading the manual won't hurt. The one for the gen2 did explain what the unfamiliar sounds the driver might be hearing were.
