prius prime diagnostic check
Discussion in 'Prime Main Forum (2017-2022)' started by poohbear1953, Aug 28, 2023.
  1. poohbear1953
    poohbear1953 Junior Member
    27
    26
    provo,ut
    was in an accident Friday the 25th,,,,the whole left side of car needs to be repaired most damage to the drivers door...my concern are the sensors and computer stuff inside the vehicle....a private collision service said their diagnostic machine can do the job i'm concerned that their machine wont do as good a job as the one at my dealership....does Toyota sell their diagnostic info to 3rd parties or is it kept in house because of the technology they use and they don't want it to get out ?
    52,396
    toyotas tech stream software is available to private concerns, even us. just make sure they have it.
    is it an insurance approved repair facility?
  3. poohbear1953
    27
    26
    provo,ut
    yes...it is an insurance approved facility ...
    52,396
    try to work closely with your insco to make sure they do it right, and use oem parts if your policy allows it.
  5. poohbear1953
    27
    26
    provo,ut
    it's the other guys insurance ,allstate , they will be paying for it ....
  6. bisco
    52,396
    do you contact them directly, or through your company?
  7. poohbear1953
    27
    26
    provo,ut
    i talked to the allstate adjuster this morning ....the guy hit me making a left turn at a green light as i was going straight ...should be cut and dry who's at fault especially when he told the officer that he didn't see me and i was only going about 12 mph...
  8. bisco
    52,396
    i'm just wondering who you contact if there are any problems with the repair
  9. poohbear1953
    27
    26
    provo,ut
    oh....can i take it to Toyota or i have to take back to the private repair service that did the work...good question , will ask adjuster .
  10. PriusCamper
    PriusCamper Senior Member
    13,075
    5,306
    Pacific Northwest, USA
    Get some tape and tape up those wires so the un-insulated parts aren't touching each other, or you could short out something in the vehicle. As long as that didn't happen and airbags didn't deploy, there isn't going to be a need to diagnose/fix anything with computers.
    And if you want to fix this car and pocket the insurance check, you could find a fender and door with side mirror at a wrecking yard in the $100 range and it's a very easy nuts and bolts job.
  11. KCWhitney
    KCWhitney Active Member
    140
    118
    Connecticut
    2025 Prius Plug-in
    If the other guy is paying, bring it to a dealer without question. Toyota has does good work for me.
