Prius Prime F/R Weight Distribution
Discussion in 'Gen 5 Prius Main Forum' started by thetoys, Nov 1, 2023.
  1. thetoys
    thetoys New Member
    Toronto, ON
    2023 Prius Prime
    XSE Premium
    Roqu3 and otatrant like this.
  2. thetoys
    thetoys New Member
    Toronto, ON
    2023 Prius Prime
    XSE Premium
    Motor Trend Review of Prius Limited
    https://www.motortrend.com/reviews/2023-toyota-prius-limited-first-test-review/
    Motor Trend List Prius Limited FWD F/R Weight Distribution as 60/40% (3211 Lbs)
    Motor Trend List Prime XSE Premium FWD F/R Weight Distribution as 56/44% (3567 Lbs).
    Weight Delta approx. 356 Lbs. mostly attributed to Larger Battery, but some to additional optional Equipment like Power Hatch…etc.
    FWD Prius Limited vs FWD Prius Prime
    Dynamically the Prime Should be a better Handling Car due to better F/R weight distribution. Battery is also Lower underneath the car vs in the car (below Seat) so Center of Gravity is better.
    … lighter Car has a lot of Handling Advantages as well.
