Prius Prime Head Unit Replacement?
Discussion in 'Gen 4 Prius Audio and Electronics' started by web1b, Oct 6, 2023.
  1. web1b
    web1b Active Member
    817
    52
    Is the base 7 inch radio in a 2018 Prime replaceable with aftermarket units? I looked on Crutchfield and they say nothing is compatible for the Prime model. If I select the non-Prime Prius, then it shows available head units.
    The radio failed and the dealer says it is failing to take attempted software updates.
    They want $1500 to replace it. An option would be to buy a used unit from eBay, but doesn’t that require a code and programming from the dealer to activate?
    If aftermarket radios are an option, what about the integration for Bluetooth phone calls, steering wheel controls and the backup camera?
    Aren’t there also some car management and diagnostic features that are embedded in the stock radio that you lose with aftermarket radios?
  2. Drakxyfly
    Drakxyfly Junior Member
    111
    23
    Usa
    2021 Prius
  3. Drakxyfly
    111
    23
    Usa
    2021 Prius
  4. web1b
    web1b Active Member
    817
    52
    Looking for something that integrate with the car the best and connect to the existing factory backup camera.
    Apple CarPlay would be nice to have, but otherwise, just getting a replacement of the existing stock radio might be best since it’s for someone who isn’t techy and won’t be able to deal with quirks and glitches that will require any amount of troubleshooting.
    If we try an aftermarket unit, it would need to be stable model that never freezes up and needs to be reset.
  5. Drakxyfly
    111
    23
    Usa
    2021 Prius
    Your best bet is probably a junkyard.
  6. Drakxyfly
    111
    23
    Usa
    2021 Prius
    Anything aftermarket from crutchfield would be the same
  7. web1b
    web1b Active Member
    817
    52
    Does it require a security code or dealer programming to install a replacement Toyota radio?
  8. Drakxyfly
    111
    23
    Usa
    2021 Prius
  9. Tony1988
    Tony1988 New Member
    Sweden
    2017 Prius PHV
    What unit did u buy?
