Prius Prime passing power in EV
Discussion in 'Prime Main Forum (2017-2022)' started by civicdriver06, May 31, 2017.
  1. civicdriver06
    civicdriver06 Active Member
    797
    324
    Germany
    In Germany the typical passing power of a vehicle is measured between 80 km/h (~50 mph) and 120 km/h (~75 mph) and it takes my gen. 3 about 7 sec. to do so,which is pretty good.
    I came across this video and as it seems it takes the Prime more than double of the time to get from 50-75 when in EV !
    So I was wondering if the guy in the video is wasting time by not pushing the pedal to the metal straightaway as he should when testing those times!
    I noticed that the power meter goes up immediately right to the end when he does the same precedure in HV mode,but it seems to take the power meter some time to go right to the end when in EV,so what is your opinion?
    Is it really that slow,is the car maybe going uphill or is the reviewer not pushing hard enough on the pedal ?
    By the way the Prime even seems to need about 2 sec. more even in HV -mode vs. the regular Prius doing 50-75.
    #1 civicdriver06, May 31, 2017
  2. john1701a
    john1701a Prius Guru
    12,833
    5,310
    58
    If you are going to pass aggressively, why would you leave it in EV mode? That's what EV-Auto is for.
    My commute takes me on a stretch of highway that has a 70 mph limit. Driving through that traffic and passing in EV mode is all I've ever needed.
    #2 john1701a, May 31, 2017
  3. Tideland Prius
    16,623
  4. CaliforniaPrius
    CaliforniaPrius Active Member
    313
    201
    Alameda, California
    This is exactly the same experience I have. The EV mode is designed for inner city driving, not for hwy. You need to take the car out of EV mode and into HV mode on hwy.
  5. bwilson4web
    16,380
    There was posting that claimed ascending a hill someone floored the car and the car switched to HV mode by itself under load. If the battery is about gone, this would make sense as it exhausts the last charge. But I thought the OP claimed that was not the case. Regardless, I have yet to see a reproducible case of the car leaving EV with charge and enabling the engine.
    Anyone else?
  6. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    The EU Prius PHV is different from the Prime in this respect. PHV EV mode is actually somewhat similar to Prime's EV auto mode, so, in Germany no need to switch, ICE will kick in at very high loads.
    #6 giora, Jun 2, 2017
  7. GasperG
    GasperG Senior Member
    1,169
    601
    Slovenia
    2018 Prius
    In the video is US spec Prime, it will stay in EV even if you floor it.
    EU spec Prius PHV will engage engine on the kick down, no matter what mode you are in. So I don't know if that will satisfy @civicdriver06 or not. In a way it will give you more passing power but you will be burning gasoline. My take is if you wan't high speed performance then engaging ICE is inevetable, so it may as well engage ICE on kick down.
  8. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    I drove my Prime up to 86mph on the highway before it automatically tripped out of Ev mode. It tripped when the speed changed from 85 to 86.
    I've driven in Ev on the highway for hundreds of miles so far - like every single day to work. Part of my trip to work is an acceleration from 0 to 50 up a 7% grade. No issues in Ev mode.
    I've done 0-60 and 30-60 testing on the highway in Ev mode. No problem staying in Ev mode.
    Yesterday, I put the pedal on the floor at 0 and took it off the floor at 62mph while climbing a 5% grade. Stayed in Ev mode the entire time.
    #8 Lee Jay, Jun 2, 2017
  9. Tideland Prius
    16,623
    Again, please be aware of the differences between the NA-spec and Euro-spec cars. :) There is no 100% EV mode in Euro-spec cars.
    john1701a likes this.
  10. Lee Jay
    5,850
    4,036
    Then I wouldn't buy one, and in fact I didn't buy a PIP partially for this reason.
  11. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    The Euro-spec car suits me better than the US-spec one.
    In EV mode the engine kicks in only when you floor the pedal and activate the kick-down switch (i.e. - extra pressure), this is a very very rare situation for me and when it does happen I do want all the power available no matter which source it comes from, and both sources together do give lot of extra power (91 kW as compared to 68 kW EV only).
    Comparison to the PiP EV mode is really irrelevant.
    Tideland Prius likes this.
