Prius Prime Plus CarPlay Upgrade
Discussion in 'Prime Audio, Electronics, and Infotainment' started by Gerry Maldi, Jul 14, 2020.
  1. Gerry Maldi
    Gerry Maldi Junior Member
    Fort Worth, Texas
    2019 Prius Prime
    I got a 2019 Prime Plus with the 7" Radio and would like to upgrade to an Apple CarPlay compatible system I live in Texas, and visited a Car Toys and they showed me several units that are compatible, however I went back to do the upgrade and they told me they don't have an unit that fits my car. I have seen some Prius owner which have done it. Any feedback where I can get it done and which radio system it is, without losing any of the OEM features such as backup camera etc Thanks for your help!
    52,398
    have you asked toyota if it is upgradeable?
    you can check with crutchfield for unit compatibility
  3. Gerry Maldi
    Fort Worth, Texas
    2019 Prius Prime
    Thanks Bisco, Toyota will only include 3 models from 2019 to be upgraded to CarPlay That is the answer Toyota customer headquarters provided me
  4. R Id
    R Id Junior Member
    Maryland
    2018 Prius Prime
    It's the same as this generation of prius for mounting purposes. Parts for me (I don't have a lot of posts so no links, sorry):
    NEW-IMC-AUDIO-AXXESS-AX-TOYUSB-TOYOTA-LEXUS-ADAPTOR
    Scosche-LSAAB-for-Toyota-Lexus-to-install-Aftermarket-Radio-Antenna-Adapter
    ADS-MRR-MAESTRO-RR-IDATATLINK-RADIO-REPLACEMENT-STEERING-WHEEL-INTERFACE
    HRN-RR-TO2-IDATALINK-MAESTRO-TO2-TOYOTA-SCION-HARNESS-FOR-ADS-MRR
    TOYK932GB-2016-Prius-Dash-Mounting (This is the mounting bracket)
    They may have changed some of the parts in the back like the usb port but it should work for you. This setup worked for both a 2018 and 2019 plus. The 2020 LE is a different head unit.
