Prius Prime Regeneration Braking Efficiency Experiment
Discussion in 'Prime Technical Discussion' started by erikrocketman1, Jun 1, 2018.
  1. erikrocketman1
    erikrocketman1 New Member
    Los angeles
    I haven't seen any posts on regeneration efficiency, and wanted to do my own experiment. Pictures below.
    Bought a Prius Prime (Plug-in Hybrid w/ 6kW reserved for eV mode only) last week and naturally needed to nerd out with it!
    Took a vacation in Lake Arrowhead, California this Memorial day Weekend. Used this opportunity to calculate the regeneration efficiency of the Prius Prime by seeing how much energy it recharges to the batteries from the top of the mountain to the bottom.
    Using the elevation difference, and the total weight of the car with luggage and passengers, found that the regeneration efficiency to be about 51%, regenerating 3.22 kWh back to the battery from a 4400 ft altitude.
    Driving 110 miles the whole day and only used 0.65 gallons of gas! Car was at 100% battery at beginning of day, going down the mountain, I was at ~42% battery before descending the mountain, and managed to top of exactly at 100% at the bottom of the mountain). 169 mpg!
    Please share your stories!
    49,492
    welcome, beautiful!(y)
    erikrocketman1 likes this.
  3. PlugmeInplz
    PlugmeInplz New Member
    22
    24
    LA
    2013 Prius Plug-in
    Its cool how you calculated this. What is interesting is the prime charged to 100% at the bottom of the hill, so the prime will not accept any more charge and brakes will absorb the excess energy. If you drained the battery at the top you could of potentially gotten an even larger charge increasing the regen efficiency. Great MPG
  4. PlugmeInplz
    22
    24
    LA
    2013 Prius Plug-in
    What was you EV to HV ratio?
  5. Roy2001
    Roy2001 Active Member
    371
    158
    Sacramento, CA
    Great information!
  6. bisco
    49,492
    stickied!(y)
  7. erikrocketman1
    Los angeles
    Actually, I got really lucky and hit 100% right before entering the freeway at the bottom of the hill, so no brake pad was used at all the whole way down!
    The entire 110 mile journey was about 69% EV driving ratio!
    HV mode didnt turn on until the last ~34 miles of my journey. Also, I didn't go into "B" mode down hill, for some reason it kicked on my engine.
    #7 erikrocketman1, Jul 19, 2018
  8. Prime Objective
    Prime Objective Junior Member
    Edmonton, Canada
    2018 Prius Prime
    Upgrade
    If you do not want to use the ICE just switch back to "D" before stopping or accelerating.
    For an explanation of "B" mode Go to wiki books and search the following - Toyota Prius/Driving tricks
    Tips likes this.
  9. axle2152
    axle2152 Active Member
    266
    210
    Atlanta, GA
    2018 Prius Prime
    Nice to know that you can regenerate like that. One question is suppose you deplete the battery in EV and switch to HV and start going down a mountain where you can regenerate a lot, say 3kW or enough to be able to gain a good bit of EV range, would you be able to enter EV mode again? I think this was something the Volt cannot do (I watched a video of Volt owner shutting his car off to restart it to be able to use EV mode after regenerating down a mountain).
  10. CraigCSJ
    CraigCSJ Active Member
    287
    144
    San Bernardino, CA
    The answer for Prime is that after regenerating awhile the car showes between 1 and 2 miles of EV available and at that time EV driving is available. It may automatically switch to EV driving at that time.
  11. lili220
    lili220 New Member
    alg
  12. JoyJonson
    JoyJonson New Member
    Thanks for info))
    I fount info what I needed
    I would like to know feedback about Toyta Camry LE;);)
    #12 JoyJonson, Dec 13, 2018
  13. JoyJonson
    :):):)сool
  14. montreal
    montreal Junior Member
    Excellent data. Thank you for posting it.
    It is worth keeping in mind that the calculations ignore parasitic losses. When ever a vehicle coasts (uphill, downhill or on level ground), it losses significant energy to aero drag and rolling resistance. That energy is gone and cannot be recaptured by regen.
    Actual wheels to battery efficiency is probably close to motor efficiency, so 70-80%?
    AldoON, chogan2, CR94 and 2 others like this.
  15. kepani
    kepani Member
    63
    67
    2020 Prius Prime
    Subscribed! I love this kind of stuff...the nerd in us! :ROFLMAO:
    Thank you for sharing this!
    Tips likes this.
  16. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    On my daily return, the car is low on charge, I have on petty good series of upgrades, so I charge to somewhere between 15-20 mpg, use most of that until the last peak. At the light I start charging again, conservatively until the actual downhill roll starts. At that point I use either drive or Brake. Both positions
    provide very small, even non existent ICE usage and gravity charges most of that portion until the bottom of the American River canyon. All basically Brake charging. The EV use is generally 65-69% Now the uphill starts, a more dangerous portion so my average speed is definite less than 30 MPH. Until the next peak, then it’s EV for the rest of the commute. I generally make it home with 5-9 miles left. I consider that a failure, I’d rather run out at my driveway. Well, next time ... maybe.
    Tips likes this.
  17. chogan2
    chogan2 Senior Member
    1,066
    756
    Virginia
    I can take a rough cut at showing that, based on amperage required to drive a steady 55 MPH on level highway. I estimate that to be 35 amps, using a Scangauge, Presumably, that's the frictional losses when driving at 55 MPH, plus motor/inverter losses.
    From that, I can adjust out the friction losses, like so, for an assumed 55 MPH or (guesstimated) 65 MPH 8 mile trip:
    And it's exactly as you said. If the motors are about 80% efficient, and you lose about 10% of the energy when you charge the battery (per https://fueleconomy.gov/feg/atv-ev.shtml), you ought to see about 70% of potentially recoverable energy end up in the battery. And that's just about how it all works out, starting from an observed 35 amps to keep the car moving along steadily at 55 MPH.
    AldoON likes this.
