Prius prime tail light conversion (non Prime)
Discussion in 'Gen 4 Prius Accessories and Modifications' started by TNeil, Sep 18, 2019.
  1. TNeil
    TNeil Junior Member
    I
    I’ve been into modifying cars for a long time and seen some crazy mods so this is probably not far out there.
    I did some research and couldn’t find anything on this topic but would (has anyone done this) be possible to convert your gen 4 non prime Prius to a Prime tail light?
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    I doubt it - it's too different. Check the profile of the back and the hatch. Unless you've got unlimited $$$ - in which case anything is possible.
  3. TNeil
    TNeil Junior Member
    I
    If it’s more economical to just buy a Prius Prime (as opposed to doing conversion) then I obviously would take the Prime..
    I ask because I’m in the market for a gen 4 and wanted to see if it’s economically feasible.
    I’ve seen some comparable Primes in my area for just a tad over 2k compared to non Prime.. if the conversion is a lot less than 2k, then it would be a go for me (buy non Prime and convert it) but if it’s around 2k to convert, mine as well get the Prime or just live with the standard tail lights..
  4. alanclarkeau
    7,045
    7,593
    Personally, I prefer the Gen4 rear - it's more focused and together - the butterfly or tuna mouth and the separate low lights of PRIME are uncoordinated.
    krmcg likes this.
  5. Prodigyplace
    12,665
    11,828
    Central Virginia
    Perhaps with parts from a junkyard Prime. You may need the carbon fiber hatch with the wavy rear window too.
    Good Luck
  6. alanclarkeau
    7,045
    7,593
    And I don't think the profile is the same - maybe where it joins the roofline, but not the guards or bumper.
  7. alanclarkeau
    7,045
    7,593
    Maybe you could go "the whole hog" and put an Aston Martin Vulcan rear on - the tail-lights are a better iteration of the PRIME lights:
    krmcg, TGrracie and Prodigyplace like this.
