Prius Reliability
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by twindad2002, Jan 7, 2009.
  1. twindad2002
    twindad2002 Junior Member
    Austin, TX
    Hi Folks:
    I recently purchased a black 2009 Prius. As I am learning about hybrid cars, I had a few questions come up concerning the reliability of hybrid cars.
    1) Are hybrid cars in general more or less reliable than non-hybrids. By reliabilty, I mean do hybrid cars have a greater lifespan than non-hybrids? Another way of thinking about reliability is the mean time between failure (MTFB)
    2) The Prius gasoline engine can turn on and off several times during the course of a normal drive. Does this put more or less strain on the engine, again affecting the reliablity of the engine?
    3) The INZ-FXE gasoline engine is an Atkinson cycle engine instead of the Otto cycle. How does this affect relaibilty?
    Any insights/data into these questions would be greatly appreciated.
    Regards,
    Twindad2002
  2. jayman
    jayman Senior Member
    13,439
    639
    Winnipeg Manitoba
    Well, here in Winnipeg, Duffy's Taxi operates over 100 Prius as taxi's. Overall they claim *much* better reliability than the typical Ford Crown Vic Police Interceptor.
  3. galaxee
    galaxee mostly benevolent
    9,810
    464
    MD
    the hybrid tech is much like the maytag man. actual lifespan data has yet to be generated in the real world, of course.
    oil pressure is brought up and the engine crank is spun before spark is applied to ease the strain. the prius doesn't seem to have major engine issues resulting in significant lifespan decreases, unless you don't take care of it.
  4. jyl
    jyl New Member
    84
    Portland
    Consult Consumer Reports' reliability ratings. The Prius is "much better than average" overall (all years), and "much better than average" in almost every category for every year. Specifically the two engine categories are MBTA for every year. The Prius has been around since 2001, long enough to have a lot of real-world data.
  5. qbee42
    qbee42 My other car is a boat
    18,058
    3,073
    Northern Michigan
    You shouldn't lump all hybrid cars into the same heap. The technology varies a lot from one manufacturer to another, and presumably the reliability does so as well.
    As the others have stated, the Prius is very reliable. It has all of the normal reliability of a Toyota, plus the mechanical simplicity of HSD. The HSD replaces much of the mechanical mess of a normal car with sophisticated electronics and software. It's expensive to develop, but not likely to fail once the development bugs are out of the system.
    To add to galaxee's comments, the Prius doesn't use a normal starter motor. Instead it has a big high-voltage motor that can easily spin the engine at speed. When the engine needs to start, the smaller electric motor (MG1) spins up the engine until it reaches running speed. Once the oil pressure is up, spark and fuel are started and the engine simply runs. There isn't really a starting cycle in the normal sense.
    The Atkinson cycle engine on the Prius is basically an Otto cycle engine with different valve timing. Reliablity is about the same, except the Atkinson engine runs with a little more compression. This is offset by the easy life of a Prius engine. RPMs are limited, and the engine never has to idle for extended periods. Mostly the engine runs at an optimum speed or not at all. It's an easy life.
    Regenerative braking does the same thing for the brakes. Most Prius brakes die a slow death from rust, not from use.
    Tom
  6. Tideland Prius
    16,059
    Hello and :welcome:. Congrats on your new car!
    1. They're no less reliable than other Toyotas. In Vancouver and Victoria, BC, they have a large fleet of Prius cabs (as well as Camry Hybrids) and they do up to 100,000 miles a year. NY has a fleet of Escape Hybrids.
    2. Nope it's fine. The electric motor starts the engine (there's no starter/alternator) and revs the engine up to 1,000rpm before ignition (vs. 400rpm for a regular starter/alternator).
    3. No different. Nothing is changed other than the timing and period of the crankshaft
  7. JimboK
    JimboK One owner, low mileage
    2,817
    187
    49
    Chesterfield, VA
    CR also rates the Prius as among those whose owners are most likely to buy the same car.
    Another source of real-world data, and another that confirms the car's excellent reliability, is TrueDelta.
  8. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    The Prius was rated the most reliable family sedan two years ago (I think it was Consumer Reports).
    Baring poor design, which we can pretty much discount by now (the current Prius engine has been used for 5 years now with no problems reported), any engines life expectancy is directly related to the power output. The Atkinson design puts out less power than an equivalent Otto cycle engine, so should last much longer. The Prius could be considered a high compression engine, but because of the valve timing is actually a low compression engine with a long exhaust stroke.
    While the Prius is more complex than many "ordinary" cars, most of the complexity is in electronics, and electronics is very reliable these days. The Prius "transmission" is actually much simpler than most cars. Try rebuilding an automatic transmission some time. ;)
  9. subarutoo
    subarutoo New Member
    1,213
    23
    Chatsworth, CA
    I've only been to the dealer once in 75,000+ miles. I got a "check Engine" which turned out to be the pump for the inverter coolant, hybrid related, and fixed under waranty, no hassle. The original tires lasted over 67,000 miles and still had legal tread when I took them off. I thought our Subarus were the gold standard for reliability, but so far, the Prius is looking better than our beloved Subarus. As an aside, my wife's 117,000 mile Outback has been in the shop for over a week to fix an elusive oil leak. She is driving my Prius, and I am commuting 90 miles a day in my 88,000 mile Impreza. What bothers me, is that she is starting to like the Prius, and can't be bothered to get her keys out to open the front door (house), and rings the door bell to get in after work. Talk about spoiled!
  10. bwilson4web
    15,388
    One measure of reliability is the number of parts. In the case of the Prius, there are half a dozen control computers that provide intelligent actuation of engine, transmission, body and battery systems. The next effect appears to be a reduction in the number of parts and more feedback on vehicle performance. Often diagnosis comes from codes set by the control computers when they notice a problem. So we have fewer mechanical parts that are operated by control computers with the ability to tweak the car and keep it running. It seems to be more reliable and that is shown in the Consumer Reports data.
    Since it is part of the normal operational scenario, the start/stop cycles have been optimized and tuned. For example, there is no 'starter gear' nor 'starter only' motor. This is a seamless part of the vehicle.
    The 76 hp engine has the same engine block and many of the same parts as the 108 hp Otto version. This means there is less stress on the moving parts and that tends to improve reliability. It is also computer controlled including the throttle. You can stop on the accelerator but it won't blow itself apart.
    GOOD LUCK!
  11. grand total
    grand total Member
    154
    ON, Canada
    Due to the aforementioned valve timing the engine runs with approximately normal compression ratio (effectively) but a higher expansion ratio than is usual. This is one of the factors contributing to it's higher than usual efficiency.
