Prius Resets after shutdown
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Kevin Caccamisi, Nov 2, 2021.
  1. Kevin Caccamisi
    Kevin Caccamisi New Member
    Bartlett
    My 2008 has been running fine. Recently bought. 80k miles. The only issue is that sometimes when I push the power button to turn the car off it resets. Like doesn't turn off but the dash lights up like it's in mx mode. Power light is steady orange. Pushing power again turns it off and everything is fine. It's almost like it electronically trips out momentarily. Suggestions?
  2. Another
    Another Senior Member
    1,802
    511
    Naples, Florida
    How old is 12v battery? I’d do a load test on it.
    SFO likes this.
  3. Kevin Caccamisi
    Bartlett
    I have no records showing how old the 12v in it is. I did the self diagnostic check and once the electric load of mx mode (acc-mode) is activated then volts go from 12.1 v (no load) to 11.5v in acc-mode. No lights or radio on.
    49,437
    that's kind of low
  5. Tombukt2
    Tombukt2 Senior Member
    9,080
    1,574
    Durham NC
    That is low change it out to AGM Deka or such.
    SM-A715F ?
  6. donbright
    donbright Active Member
    241
    150
    33
    oklahoma
    Also maybe check your battery connections make sure they are tight.
  7. Another
    1,802
    511
    Naples, Florida
    Check date code on battery. If more than three years old, get new one.
