Prius runs fine when (cold), but low MPG and engine stays on when hot (MarieAnie's thread)
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by MarieAnie, May 5, 2019.
  1. MarieAnie
    MarieAnie New Member
    Georgia
    #help me
    Hello, I'm new here and I hope you will help me, you're my last hope, because I have already tried everything. It's aready quite hot in my country now. So, as I said, engine running all the time. Low 28MPG. Today I changed battery, 7 of them where dead. Tech cached the car on compiuter and there weren't any error or thomething like that. They also changed vent of battery, but there no any reasult. After the car gets hot, MPG is getting low and low and low and the engine works only on the fuel, not on battery. When I tund off the engine and the car gets cooler, it starts working on the battery, but after getting hot the car, it works only fuel again.
    What ealse can be? Compiuter diagnostic shows nothing. Please, any help
    48,945
    you need a new battery, how many miles on her?
  3. MarieAnie
    Georgia
    I chaked them, 7 was dead and changed, I also changed vent system.
  4. landspeed
    landspeed Active Member
    351
    198
    MarieAnie - is the car itself actually overheating? Does it have any warning lights?
  5. MarieAnie
    Georgia
    Yeah, by itself, when I'm driving and car is cool it warks good, no any warning lights, and when it's getting hot, doesn't work on battery any more, only running fuel engine low mpg 28_30.
  6. bisco
    48,945
    changing cells doesn't work, you need a new battery, or at the very least, a complete balance procedure
  7. bisco
    48,945
    i suspect her battery is overheating, and self protecting limiting of output.
  8. landspeed
    351
    198
    I strongly suspect this too - it would be awesome if the problem was that the battery fan wasn't spinning and that was the cause of the problem, as the car could be saved quite easily!
    (I assumed Gen 2 but it could be Gen 1. I hope it isn't Gen 3 otherwise we need to consider the fact that the (E G,r) I think, gets blocked, and destroys the he G). I have deliberately obfuscated those terms because they would induce fear in most car owners! Hopefully it is a Gen 2 :)
  9. landspeed
    351
    198
    To MarieAnie (and others where applicable):
    When you say the problem is only when hot, can I ask:
    -> Is the problem only when the weather is hot outside?
    -> Or do you mean, the problem only happens when the car has been driven for a few minutes?
    Also - where do you stay? Are you in the USA, Georgia, or somewhere else?
    Also, what year is your car made? It is somewhere between 1999 and onwards, probably 2001 or later...
  10. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,476
    Bay Area, California
    2019 Prius Prime
    There should be warning lights for these conditions. Is the dash working, as in is the combo meter up and running?
    SFO likes this.
  11. SFO
    SFO Senior Member
    5,286
    4,225
    Northern California
    Seems odd that we have no 'codes'. Might try a new "tech", or buy a $1 USD OBD2 bluetooth adapter and the appropriate App.
    Given the problem (read the thread) and the steps taken (HV battery / HV fan), it sounds like a failed inverter pump or trapped air :whistle:
    There should be some DTCs logged, somewhere.. or not :cautious:
    bisco and Raytheeagle like this.
