Prius runs for 8 secs then STALLS. DTC P3191 PLZ Help!!!
Discussion in 'Gen 2 Prius Main Forum' started by svldvc, Aug 22, 2011.
  1. svldvc
    svldvc Member
    102
    Charlotte NC
    2014 Prius v wagon
    Hi guys.
    [[[**Before you guys start saying "Use the SEARCH function", read what I write***]]]
    Because I HAVE searched the forum and read EVERY post that had a problem w/ same DTC code...still no luck.
    Okay I have a 2006 Prius, 80K miles. Car worked fine & flawlessly until was cruising on HWY and my car just lost all power and shut down. :confused:
    Restarted the car...car runs for about 8 secs, and then stalls (as if it's chocking/not enough air).
    Scanned the car & it came back with P3190 (probably dirty Throttle Body)
    I replaced Throttle Body, MAF (mass airflow sensor), and TPS (Throttle position sensor), and air filter.
    **I know these were NOT necessary, but I did just to be SURE I'm working with "good" working parts and try to narrow down my problem** ;)
    Scanned the car, the P3190 has WENT AWAY! :p
    Started the car...the car runs for about 8 secs...then stalls...
    Scanned the car, got a new code: P3191
    Replaced the Sparkplugs (they were charred).
    Started the car....ran for about 8 secs...stalls. (HV Battery has almost FULL charge). 12V Battery FULL CHARGE by the way).
    My scanner came back with "Code-Assist" and it said common 'fixes" were to "Adjust Engine Oil Level"....??? will do that tomorrow.
    FYI: Replaced oil about 4000 miles ago (Synthetic) drove no problem.
    Last time fueled up to the FULL and drove 100 miles since..(so probably NOT dirty gas
    PLZ HELP: if someone knows that the problem "might" be and I'll check it out and see if I can get it to work.
    **Patrick Wong if you're still here, feel free to chime in w/ your expertise knowledge** :cheer2:
  2. Patrick Wong
    18,200
    6,493
    1. I would question whether the engine actually was burning fuel and running for the 8 seconds, or if MG1 is just spinning the engine.
    2. DTC P3190 and P3191 indicate poor engine power in the first case, and engine no start in the second case.
    3. Regarding the parts that you replaced, did you buy new parts or did you use salvage? If the latter, how do you know the parts are good?
    4. I suggest that you check fuel line pressure (should be at least 44 psi upon startup.)
    5. Check the engine coolant temperature sensor, crankshaft position sensor and camshaft position sensor (download repair manual info at techinfo.toyota.com for testing info, if needed.)
    6. If all of the above are found good then the engine ECU may have failed.
    2 people like this.
  3. svldvc
    svldvc Member
    102
    Charlotte NC
    2014 Prius v wagon
    Thanks Patrick.
    I will do 1-by-1 as you suggested.
    I know I put on "good working" parts, because I have another Prius that is my daily driving car, and it works 100% flawlessly, so I know that those parts that I put on are working and not sticking etc. etc.
    Thanks for your advice I will try to tackle the fuel lines pressure test today.
    **I know this is asking too much, but I got to run right now to my other car...so I can't research right now, but if you by ANY CHANCE...KNOW any links to: How to test the fuel lines, (tools, procedure etc.)...I would be Tremendously Grateful to you.**
    If not...don't sweat it...I will spend all night researching on HOW-TO's...
    Also...(don't know if it's wise)...but what Just if...IF...it's the ECU...can I swap ECU from my working Prius to see if that will fix the problem?? (or is it not recommended)??
    If YES: Where is the ECU located?
    Thanks.
  4. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    duplicate post
  5. SageBrush
    11,627
    2,533
    Southwest Colorado
  6. wick1ert
    wick1ert Senior Member
    1,311
    183
    Delawhere
    If you're still stuck, and by chance need to use TechStream let me know by Thursday. I'll be riding through that area on Saturday on my way to Cedar Point in OH again. I'm familiar with rte 322 around state college, and if I recall, I'll be going by the HD dealership (I recall you mentioning before in a post to me that you're familiar with where they are) while working my way up to I80. Since I'm staying east of Cleveland, I could leave about 30 mins earlier if you need and let you borrow my cable.
    Just shoot me a PM and let me know. We can work out details if need be.
  7. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    i saw you replaced the spark plugs.. have you thought about the ignition coils? i've had one fail in the past. i only replaced the one that failed.
    it's been said in the past... many years back by the wisest of prius folk... that there is a procedure to force everything to reset... it involves resetting the car many times over in a few second period (foot on brake... full power up.. i do it at least 5 times really quickly). any time i've ever had errors, that is what i've done and it seems like a giant safe mode for the car (ign coil failures especially.. one due to age and one incident where i flooded it during a storm... also the one time i had christmas tree failure on the expressway, like you described)
  8. svldvc
    svldvc Member
    102
    Charlotte NC
    2014 Prius v wagon
    I thought that at first too...but does MG1 burns gas?? I thought it didnt?
    Because WHILE the car was running for 8 secs or so...I bent over and smelled the exhaust fumes..and it was 100% deff. Clean CO2 gas...just like on a normal car.
    So I think fuel was burning. (or am I wrong)? :confused:
  9. svldvc
    svldvc Member
    102
    Charlotte NC
    2014 Prius v wagon
    ::UPDATE::
    **was reading though similar threads w/ same problem and someone posted this:
    "The Tech checked the EFI relay; checked for oil puddled in intake"**
    When I removed my TB (Throttle Body), I DID see some oil puddled inside the intake (under the TB ) Is that "normal"? Or has the car been overfilled w/ Oil?
  10. SageBrush
    11,627
    2,533
    Southwest Colorado
    ^^ lol, welcome to my world :)
    Since I am the only person who has ever put engine oil in my car I am quite sure there has not been any over-filling, yet I too have a sheen of oil under the engine cover. When I asked PriusChat a while ago if this is normal I was told (in so many words) "of course dummy, you have to lubricate the valves!"
    When the car was at the dealership for its P3191, the mechanic also mentioned the oil slick and offered to clean it up, but he did not think it was causing any problems so I declined the service. I have peeked at the slick over the years and I have never seen anything that even approaches a mm in height, my car runs fine, and while I *still* do not know how 'normal' it is, I have not noticed any problems.
    Just a thought -- perhaps the oil is from an oil fill when I did not use a funnel, and some oil splashed into the compartment ?
  11. David Beale
    David Beale Senior Member
    5,963
    1,987
    Edmonton Alberta
    No, it's pretty normal to get oil in the intake. It comes up through the PVC system. Also keep in mind the Prius runs a sudo Atkinson cycle. So valves are held open on compression stroke for a bit. This will force some of whatever is in the cylinder into the intake. There IS -some- oil in there to lubricate the rings. Over time the tiny bit of oil that gets forced up builds up as there is nothing in the intake to clean it out (no fuel). You can also get some oil up there when using engine braking. The Prius does this in "B" mode.
    So it's normal. Now this is not to say the oil can't hurt anything. It -can- contaminate sensors. But we don't have legions of Prius owners with problems, so I think we're safe there.
    Back to the OP. It's possible you got dirty gas. It has taken time to clog injectors (there is no fuel line filter in a Prius, just a "strainer" in the fuel tank). It's also possible the fuel pump has failed. So as Patrick said, first thing is to check fuel line pressure. It's an involved procedure, and as you are in the US you can inexpensively access the Toyota info site. Do so. I just read the shop manual and you want to do so as well. The fuel system part is over 4 Meg bytes and copyright protected, so I can't post it for you. Sorry, but for $10 or so you can download it and the rest of the manual from TIS.
    As for the exhaust "smell" test, it's not a very good test, as any air passed through a long used exhaust system will smell just like it did when the engine was running. It just won't warm up.
  12. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,517
    38
    Santa Fe, NM
    Carbon fouling at this mileage is not normal. It could be bad gas. 100 miles is only 2 gallons.
    I don't know that there has ever been a satisfactory explanation for the oil puddle, but it in and of itself doesn't seem to hurt anything. Is your oil level in between the notches on the dipstick?
    I recall the problems that you had with your other car. Did you swap parts back and forth between this one? Is there a chance that something was not reconnected correctly? Although it is hard to think of what could have been disconnected or loose and not cause immediate codes, or cause a persistent rich burn condition.
    I like the idea of the 5 on/off reset and/or battery negative disconnect for 5 minutes. I still wonder if that is what fixed Sage's car, since all the reprogramming does is make the engine crank longer.
  13. SageBrush
    11,627
    2,533
    Southwest Colorado
    That might be the answer in my car.
  14. svldvc
    svldvc Member
    102
    Charlotte NC
    2014 Prius v wagon
    Thanks guys...I really appreciate the Help I'm getting.
    I would LOVE to test the fuel line pressure, and I have the TSB on how to do it, but I don't have that gauge tool. Does anyone has one and lives close by that I can borrow it? Would hate to buy it and find out my fuel is fine and never use that gauge ever again.
    Next thing I'm doing is
    1.) Replacing my Ignition Coils
    2.) Draining a little bit of oil (since oil is a "tad" bit over the top line)
    3.) Replacing the ECU (if that fails...then I'll check the fuel line pressure)
    I will get back with results.. ;)
  15. svldvc
    svldvc Member
    102
    Charlotte NC
    2014 Prius v wagon
    Okay...
    1.) drain some oil (for the level to go down)
    2.) replaced ALL Coil Igniters
    Still no luck...still stalls.
    Last things I think are:
    1.) ECU
    2.) Fuel lines <---but doubt that fuel pressure would go "bad" out of a sudden while driving ... (but maybe I'm wrong)
    I think I will give up on this car and just sell it as is for cheap. $8K maybe.
  16. Patrick Wong
    18,200
    6,493
    I do not understand this post. CO2 is carbon dioxide, an odorless gas. Perhaps you meant to say you smelled HC or hydrocarbons?
    I do not know why it is so improbable for the fuel pump motor to weaken or fail. If you smell a very strong odor of unburnt gasoline in the intake manifold after your attempts to start, then the fuel pump and fuel injectors are at least providing some fuel to the engine. However this does not totally rule out the fuel system unless you measure fuel pressure and find it to be correct.
    I question whether you can sell the car for $8K if it is not running unless you can find a very unsuspecting buyer.
    Why not invest $200 or so with your local Toyota dealer service dept to have the Prius tech develop a diagnosis for you?
  17. seilerts
    3,326
    1,517
    38
    Santa Fe, NM
    +1. Patrick's advice is spot-on.
    I strongly suspect a fuel problem: bad gas, out of gas, low rail pressure, etc. Drag it down to a dealer if all else fails.
    Don't sell a $12K car for $8K.
  18. garglo
    garglo Member
    99
    45
    Port St Lucie, FL
    2020 Prius Prime
    Will starting fluid mess up the MAF?
  19. richard schumacher
    7,664
    1,043
    United States
    There's no reason to take the risk. Starting fluid will not start the engine, and if it did it wouldn't fix the underlying problem(s).
    Would anyone pay even $800 for a car that isn't running?
  20. svldvc
    svldvc Member
    102
    Charlotte NC
    2014 Prius v wagon
    I'm wondering if the "dealer" has a way to check the ECU...to see if it's faulty..?
    I hope they don't just stick up an OBDII reader and say: "ops, no codes for ECU, so that means ECU is good"!!
    I dont really trust dealers, because when the issue 1st happened, I took it to a dealer to tell me what's wrong w/ the car, and all that he did is scan it w/ OBDII scanner and gave me the same P3191 code and told me to pay him $110 (which I did, had no choice) :mad: :mad:
    So I wonder if they will do the same thing about my ECU.
    Or should I just save my money and not waste my time w/ the dealer? :confused:
    Thank you for all of your post and replies guys..
    I'm soo BLESSED to be part of this amazing forum.
    I learned A TON about Priuses...and with each problem I learn more and more...willingly or unwillingly :D :D :D
    Still love Priuses :cool:
