Featured Prius runs on E85
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Pega5u5, Apr 9, 2017.
  1. Pega5u5
    Pega5u5 New Member
    CA
    Three Touring
    Prius runs on E85 with no problems, with great bebefits to the car and enviroment.
    telmo744 likes this.
  2. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,318
    Central Virginia
    Don't you mean great benefits to the corn lobby? :D
    PosauneGuy likes this.
  3. bwilson4web
    15,513
    Interesting. I did a similar experiment with the 1.8L, 2010 Prius, and other than a check-engine light, it ran fine. Eventually I found E50 ran without the check-engine light and a code that indicated it could not increase the injection timing.
    Unfortunately the local cost of E85 did not make economic sense. The cost per mile was higher than E10. But the retail price of ethanol was much greater than the wholesale price. If sold with the markup as wholesale gasoline, it would make economic sense.
    There are aftermarket hacks that adjust the injector timing, keeping the injectors proportionally open a little longer, so the car does not throw a code.
    49,397
    ethanol is as confusing as climate change.
  5. Prodigyplace
    11,696
    11,318
    Central Virginia
    It is as politically charged too.
    ShenmueTacos likes this.
  6. wjtracy
    wjtracy Senior Member
    11,321
    3,590
    Northern VA (NoVA)
    Nice video...
    Questions-
    Any changes to car (Prius E85 Kit?) sounds like no?
    Are you running E85 or mix of E85 and Regular?
    What is MPG impact vs. gaso?
    What is cost comparison vs. gaso ?
  7. Trollbait
    11,512
    If the car isn't made for E85, you risk damage to the fuel system long term. The water picked up by ethanol from gas station tanks tends to be salty and acidic.
    Raytheeagle likes this.
  8. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    Owners manual directly warns you not to do this due to risk of damage. Check
    Warning lights warn you you are doing damage. Check
    You admit you have done this on a national forum. Check
    I am not predicting the warranty work will be covered.
    wjtracy and Raytheeagle like this.
  9. bwilson4web
    15,513
    • I appreciate anyone who 'looks through the telescope'. Please keep us informed of your progress.
    I've done 'run the tank dry' on:
    • +30 times - Gen-1 Prius
    • +6 times - Gen-3 Prius
    • 1 time - Gen-5 Prius Prime
    • +10 times - BMW i3-REx
    Your experiment has merit.
