Prius Sat Nav region code problem
Discussion in 'Gen 2 Prius Audio and Electronics' started by Watershack, Nov 27, 2009.
  1. Watershack
    Watershack New Member
    UK
    I have brought my Prius from Australia (region 4) to the UK (region 2). I have tried to obtain a UK sat nav data disk but the sat nav will not read it apparently due to this region code issue.
    Whilst you can eliminate the region code issue with movie DVDs the sat nav uses database files with a .kwi extension.
    There is a region.kwi file on the disk and it is possible to decode this into hexadecimal but that is as far as I can get.
    Has anyone come across this or any suggestions to address, websites etc to contact? Any help appreciated :)
  2. hvanwersch
    hvanwersch Junior Member
    If your navigation system is a generation 5, as I presume it is, a Hungarian chap who has sorted out this stuff is likely to help you. Send him an e-mail at: [email protected]
    Good luck.
    Herman
  3. Watershack
    UK
    Thanks Herman I shall certainly try and get in touch with your contact.
    I have got both my Aus nav disk that works and a UK mapping disk that matches as the part for the Denso drive unit but is not recognised. I have also worked out how to combine files if required with a combination of Nero and ISOMagic but that's as far as I could get without understanding the file structure of the .kwi databse files. :)
  4. goldendel
    goldendel Junior Member
    Sydney, Australia
    Did you have any luck with this? I am preparing to move to the UK from Sydney and would like to take my Prius. Did you also manage to convert from kilometres to miles?
    Many thanks,
    Tim
