Prius self-started!
Discussion in 'Gen 3 Prius Main Forum' started by Kermit262, May 3, 2011.
  1. Kermit262
    Kermit262 Member
    112
    45
    Central Ohio
    Last night I pulled up to the gas pump to fill-up ($4.19 per gallon is less painful in a Prius, BTW). I turned the car off, then pressed the power button once, so that the radio was on for my wife and daughter. I stepped out of the car with the key in my pocket. I heard the warning beeping, which is the Prius telling me that the car is on (Aux mode, I think it's called, just the radio) and the key is not in the car. I ignored it and proceeded to fill up.
    When I was almost done filling up a few minutes later, the Prius "fully" started all by itself! My first indication was that the engine turned on, then I looked into the car and saw the display had changed such that it was showing 0 MPH. My wife and daughter didn't touch the power button, and in fact wondered if I somehow turned it on remotely.
    Has this ever happened to anyone else? It was a bit worrisome pumping gas into a running car. :eek:
    49,478
    i hate when that happens! (you probably had your foot on the brake when you pressed the start button.)
  3. richard schumacher
    7,663
    1,038
    United States
    Either you didn't shut it off or someone reached over and pressed the button. It did not turn on by itself.
  4. DonDNH
    DonDNH Senior Member
    1,711
    654
    Nashua, NH
    Four Touring
    Make a habit of ensuring the vehicle is in Park when using Aux mode.
  5. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    I've seen sort of thing happen before. I've had my Prius spontaneously drive forward when I forgot to put it in Park. I've also nearly shot myself in the foot when I forgot to clear the chamber in a rifle. Almost certainly you left your Prius in Ready.
    Tom
  6. jfultz14976
    jfultz14976 New Member
    Kansas City, MO
    Just hit the EV Button! That's what I do, have never had a problem....although I only have 3K on the odometer. :)
  7. BrettS
    BrettS Active Member
    290
    136
    Orlando
    I actually had the same thing happen yesterday. I pulled in to the parking spot at work while I was listening to something on the radio. I didn't want to leave the HSD on to drain the HV battery or run the ICE, so I hit the power button to turn the car off, then immediately hit it again so I wouldn't miss much on the radio. I'm reasonably certain that I didn't have my foot on the brake, but I was quite surprised when the ready light came back on when the car booted up.
    I tried it again, but this time I paused for a second or two before I turned the car back on after I turned it off, and this time it came back up in accessory mode as expected.
    I haven't tried to duplicate this, but given that you experienced it as well I suspect that all Gen III's will do it.
  8. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
    I'm waiting for the thread titled "Prius took off without me and abducted my wife and kid!"
  9. Kermit262
    Kermit262 Member
    112
    45
    Central Ohio
    LOL - my daughter suggested (in some seriousness - she's young) that it might be the ghost of bin Laden. I told her I'm reasonably certain it wasn't his ghost, and even more certain that if his ghost existed, it wouldn't be in central Ohio. ;)
  10. twittel
    twittel Senior Member
    1,605
    148
    Mt. Pleasant, SC
    Don't be too certain about that. There is rumor that B. L. was seen having lunch with Elvis at the local Burger King here in Pinehurst, NC.
  11. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    Skynet!!!
  12. wesayso
    wesayso Member
    385
    35
    Hampton, VA
    Nah, Elvis was kicking the shit out of him with his blue suede shoes.
  13. Dweezil
    Dweezil Cat Juggler
    162
    26
    St. Louis
    When I was washing my car the other day in the driveway, I somehow locked the doors(heard it beep) when I was spraying the door handle with the hose. The fob was in my pocket, I was about 6' from the car, and it was a sunny day. I have NO idea how it could've done that, unless the water acted as an extension of me.
  14. 32kcolors
    5,683
    953
    124
    Redondo Beach, CA
    Happens to me all the time while washing my car. Enough water pressure at the handle will activate the sensor.
  15. BhamPrius
    BhamPrius Member
    128
    Bellingham, WA
    As an aside, when filling up at the gas pump, do you all keep the Prius running or turn it off?
  16. BrettS
    290
    136
    Orlando
    There's actually a note in the manual that water on the handle can activate the touch sensors to lock and unlock the door if the key is in range (and 6' is probably on the very edge of the range). As I recall it even mentions car washing and heavy rain as possible triggers.
  17. 32kcolors
    5,683
    953
    124
    Redondo Beach, CA
    Turn it off. You still run the risk of the engine turning on if the battery SOC is low enough.
  18. itonarely
    itonarely Junior Member
    36
    Miami
    My youngest reached over from the back seat the other day while I was loading a few things through the hatchback and pressed the START button on my 2011. On doing this the car started up and while the key device was obvioulsy in range he was nowhere near the brake pedal.
    Other family members were in the vicinity of the vehicle at the time but I couldn't see that anyone else was anywhere where they could have touched the brake pedal.
    I haven't been able to reproduce the incident but I was surprised to find that someone else had had a similar experience.
  19. 32kcolors
    5,683
    953
    124
    Redondo Beach, CA
    This is stated in the manual and probably what happened to the OP.
    Page 165 in manual:
    "Even if the “POWER†switch is turned to off and then quickly re-pressed, the “POWER†switch mode may not change. After turning the “POWER†switch to off, wait for a short time before operating again."
  20. BrettS
    290
    136
    Orlando
    When you say the vehicle started up, do you mean it actually came up to Ready mode? If so, that is definitely not good and you might want to have it checked out.
    However, if the key is in range and you press the power button without pressing the brake the radio and some of the other 12V accessories will come on, but you can't actually put the car in gear or drive it anywhere. This is equivilant to turning the key in a regular car to the ACC (accessory) position and not starting the engine. You can tell it's in this mode because the Ready light will not be on. This is perfectly normal and likely what happened here.
