Prius shut off while driving
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Wilby, Dec 30, 2019.
  1. Wilby
    Wilby New Member
    First I'll tell what happened. Sat for a bit and now the battery is dead. Was able to get it jumped and was driving and it suddenly died. No lights on the dash at all, no electric at all, just dead. There was a high pitched alarm ringing for about 5 min. Checked engine, and it was hot, noticed the oil was low, topped off, and when tried to jump the alarm came back on. Disconnected the battery for five min to reset the computer. Tried to jump and it worked. Drove for 30 min then it happened again. Engine not hot this time. Waited five min to reset computer, then it jumped off and made it home fine. Doesn't seem to be the HV battery. Wondering if the dead starter battery is tripping the computer into shutting it down somehow. Any advice would be great. Thanks
  2. JC91006
    16,482
    8,400
    Lack of maintenance probably killed the car. You should check everything, including your 12v battery health.
    You probably overheated, you were low on oil, you may also be low on coolant.
    I don't think a low/weak battery would cause it to shutdown while it's on. And then you're able to start it again later. A dead battery won't allow you to do that
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,229
    5,915
    Columbia, SC
    When you say the oil was low, how low do you mean?
    The first thing I would do is get the 12v battery fully charged and then see where things are at.
    49,488
    welcome!
    is there turbulence in the inverter fluid reservoir?
    dubit, Raytheeagle and SFO like this.
  5. George W
    George W Senior Member
    911
    511
    San Antonio
    Have you ever gotten yourself an OBD2 code reader and a smart phone app like Torque, or Dr. Hybrid, to give you more information about your Prius? A better picture of your battery's health would focus your resources better.
  6. George W
    911
    511
    San Antonio
    Maybe I misread, but it seemed like he did have to jump it a 2nd time. Anyway, a weak cell may not hold the 13.8 V that is continuously applied during Ready mode. Agree with TMR-JWAP, would definitely pull that 12V and take it to get tested.
  7. JC91006
    16,482
    8,400
    There are probably multiple issues with the car, but I don't think the 12v is what caused the car to stop while driving. It definitely is a problem is you have to jump start it
    Raytheeagle likes this.
  8. George W
    911
    511
    San Antonio
    True, BUT the reason the 12V is being emphasized, is that it adds all kinds of weird issues when it's sick. A healthy, properly connected 12V will allow you to focus on other real issues insteadof chasing after ghosts.
  9. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
    Welcome to PriusChat!!
    Please check the maintenance history at http://toyota.com/owners
    What is the current vehicle mileage?
  10. Wilby
    Wilby New Member
    thanks for the response. Not sure what this means. Does this mean turn it on and see if there are bubbles in the reservoir tank?
  11. strawbrad
    953
    999
    That sounds like the alarm on the ABS computer. The computer is located just above the gas pedal. That really loud and annoying alarm is there to tell you there is something wrong with the brakes!
    As others have said, get a good 12 volt battery and read the error codes.
    #11 strawbrad, Dec 31, 2019
    JC91006 likes this.
  12. bisco
    49,488
    yes, make it ready and open the reservoir. the fluid should have some movement
