Prius side moulding installation heads up
Discussion in 'Gen 2 Prius Main Forum' started by Margana, Aug 13, 2008.
  1. Margana
    Margana Junior Member
    24
    Portland, Oregon Metro
    I ordered a set of side mouldings from http://www.metrotpn.com/ProductCollection.aspx?CollectionID=25&CollectionIndex
    There is a minor "head's up" on this project.
    The price is very good ($109) The shipping was very fast (received 8 days from time of order). This is an OEM type moulding with exact color match. It is definately a DIY project as you apply masking tape to establish a level line (after the tape goes on, hold the mouldings to the masking tape edge and look at how it will all go on; the masking tape line might "bow" reposition the tape so it's straight). After it's all prepped, and ready to install, you remove a few inches of the adhesive backing at the end of the moulding which will be placed next to the door edge. It is very easy to install, as you can easily keep the moulding aligned, as you pull more of the backing off the adhesive and press the moulding to the door.
    ATTENTION. At the "bullet" (pointy) end of the moulding, you may notice that the red backing is "patched". There is a peice of masking tape that is bridging a bullet shaped piece of backing to the rest of the backing of the moulding. This piece of masking tape is not strong enough to strip the bullet end of the backing off the adhesive during the installation process. This will leave the bullet shaped part of the moulding unattached (you might not notice as you are congratulating yourself for installing an OEM looking body side moulding).
    So as you are installing the moulding, when you get 4 or 6 inches from the bullet end, you will need to pull off the backing at the tip (pull off the small piece of masking tape that bridges the backing before you get ready to install the moulding is my suggestion).
    If you do not notice this, is is still possible to gently pull the bullet end of the moulding away from the door, and using a good pair of tweezers, pull off the backing. The clearences will be tight.
    Hope this helps.
  2. rstange1
    rstange1 Junior Member
    Victoria, BC Canada
    Thanks for posting! I installed my mouldings today and learned this lesson the hard way. No harm done, but I was mildly panicked until I got it all sorted out. :eek:
  3. Margana
    24
    My next project is a 2 inch wide (rear) bumper gurad. The color is not an exact match to my Pearl Driftwood (Pewter Sand) but it is a close color. http://www.eurobumperguard.com/product_bumper_guard.html
    The price is right even if you pay for the anvil cutter tool. My only pause is that there is no tapered leading edge. The corner bumper protector might be a better choice. I assume it has finished edges....(And no need for a cutting tool)
  4. Boo
    Boo Boola Boola Member
    5,051
    483
    97
    Flushing, NY
    Hi Margana,
    I have those bumper strips. If you want to see pictures of them on my car, see my pictures here:
    http://priuschat.com/forums/ca-san-....html?highlight=bumperdefender.com#post460797
    BTW, I think that the manufacturer and distributor is BumperDefender.com, and you can buy them at BumperDefender.com for a little less than eurobumper.com.
    Regarding the lack of finished points, I don't think the strips need them. When similar strips come on factory cars, they frequently don't have finished points either.
    But you do need the anvil type cutter to cut them properly and cleanly (anvil type cutters have one cutting blade on top which drops down directly onto the flat "anvil" bottom; as opposed to "bypass" type cutters, shears and scissors which have two cutting blades which "bypass" each other).
    However, you may already have such shears in your garden shed. They are identical to anvil type pruning shears. In fact, they're one and the same. Indeed, the ones sold by eurobumper.com and BumperDefender.com are the exact pair of anvil type pruning shears sold at Home Depot and other places under the "Fiskars" brand name.
    If you do get these bumper guard strips, you'll need an 8' strip for the rear bumper, and two 3.5' strips for the front bumper (one strip for each side of the front license plate holder). Those lengths will enable you to cut the strips at the crease surrounding each wheel well (see below).
    For the rear bumper strip, I would install it so it is above but touching the center crease that runs the length of the rear bumper.
    For the front bumper strips, I would install them so they are as close as possible to being above but touching the center crease, but avoiding the round toll hook cover on the driver side of the front bumper as much as possible. I think that you can get away with covering only the bottom 1/8 of an inch of that round toll hook cover.
    For both the rear and front strips, I would extend the strips to the crease that encircles and is around two inches from the wheel well opening. If you look at my pictures, you'll see what I mean.
    Be careful when you install them. I think it would be useful if you had another person stand back ten feet when you're gradually stretching and pressing down on the strips. That person could make sure that you're laying them down straight, without that wavy look that I have at two spots on my rear bumper strip.
    Good luck. Feel free to PM me if I can be of any help.
    P.S. If you're mainly concerned about protecting your rear bumper, you can consider getting one of those black rubbery mats that hang over and cover the rear bumper. The best looking one is made by BumperBully.com. You can see a picture of it on my car here: http://priuschat.com/forums/newbie-forum/50916-someone-hit-my-prius.html
    Then as to the front bumper, you can get little, black, round, spool-like, rubber bumpers from NoBump.com/GirlsLoveWheels.com, which attach to the top two screws of your front license plate. They'll protect your front bumper a little, and protect the rear bumper of the parallel parker in front of you. You can see these little bumpers in the first group of photos I've linked for you above.
  5. Boo
    5,051
    483
    97
    Flushing, NY
    Margana,
    For the BumperDefender.com or eurobumper.com bumper guard strips, did you get any color samples besides the Pewter Sand?
    It seems that there might be 2 or 3 other color samples worth getting that sound like they may be a possible match to your Driftwood Pearl -- the Bronze Beige, the Beige, and maybe the Heather Silver.
  6. Margana
    24
    Thanks, Tom. The pricing is the same. As for the color, I actually asked for the Bronze Beige, but in the ordering section they asked for my Prius Color (Pearl Driftwood in the USA and I believe, Aztec Bronze in the UK) and sent me Pewter Sand as presumably, they thought it a better match (and indeed it is close).
    I suspect that with your Magnetic Gray the leading (cut) edge will not "show". Also, I see with your angle cut which parallels the wheel well, it is not noticible.
    I did sent an email about the edge finish of their corner bumper guard, but the full length is best for protection, I think.
  7. Boo
    5,051
    483
    97
    Flushing, NY
    If you do get the full length strips, you'll have to experiment with the location of the front strips.
    Unlike the rear bumper, the front bumper's crease does not run the length of the bumper. The top edge of the air dam grille is above the crease. Then the front license plate holder interrupts everything. Then you have to account for blocking off as little as possible that round tow hole cover on the driver side.
    If I could have a do-over of the front strips, I think I would see about installing them at a location similar to the rear, i.e., touching but above the crease from the wheel well to wrapping around the corner, then either continue going straight across along the crease to the license plate or angling it slightly to accomodate the higher top edge of the air dam grille. But before removing the plastic to expose the 3m sticky side, you can experiment with the location of the strip to find what suits you.
    BTW, if I didn't live in NYC where we frequently have to squeeze in and out of parallel parking spaces that are only a little longer than our car (which means that out of necessity, parallel parkers have to "tap" the bumpers of the parked cars behind and in front of them), I think I might not get the bumper strips if I wasn't satisfied with the color match. But in my case, I was satisfied enough with the color match anyway. I think that the bumper strips actually look pretty good.
    Finally, if you don't feel like installing the strips yourself, you might be able to find a good body shop that will do them for you for around $50. Your dealer might do it too. But my dealer actually sold the same strips for $300 installed. Which means that they charged over $220 for labor!
    Good luck. And congrats on your Prius.
