Prius side swiped a truck, repairable?
Discussion in 'Gen 3 Prius Main Forum' started by JStrenk, Jan 2, 2019.
  1. JStrenk
    JStrenk Active Member
    203
    101
    Ravenna
    My sons friend sideswiped a truck and they totaled his 2010 Prius.
    I'm thinking about buying it and fixing it up for my daughter.
    I've repaired other cars in the past from head on collisions and they turned out well.
    Usually going to the junkyards to pick up parts. Been through a couple state inspections to get a salvage titles for the cars.
    I can paint so that's not a problem. How much can white paint cost... :)
    Heck I even had to repair my Prius after my son dove it into a ditch and through a gas line vent one day.
    I'm going to look at it later. I might get it for $1000 if not less. My daughter loves my Prius and If I can get one cheap.....
    First Impressions?
  2. JC91006
    16,480
    8,397
    My first impression is you don't really like your daughter...much
  3. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,318
    Central Virginia
  4. JStrenk
    203
    101
    Ravenna
  5. JC91006
    16,480
    8,397
    Jokes aside, you won't come up too far ahead on this car, even at $1000
    The body work and parts will run you maybe $2000 DIY? Then you have the electrical issues that can arise from a car that's been sitting (looks like that car has sat for a while). If you need a new battery, that'll be $2000+.
    Assuming that will be all the expenses (which probably not all of it), you'll be at $5000. Which is really how much a 2010 will cost you nowadays..
  6. JStrenk
    203
    101
    Ravenna
    Surprisingly she does like Priusi (Priuses?) Her current car is a Jeep Liberty that gets something like 14mpg on a good day.
    If the car isn't tweeked, I can fix it. I wouldn't get it if the door doesn't line up when closed.
    If it's just replacing the bumper faciahood and bolt on a new fender. I'm good.
    Looks like it will need a new windshield and headlight also.
  7. JStrenk
    203
    101
    Ravenna
    It's only been sitting for 4 days now.
    Main Battery is probably not a problem. Maybe the 12 volt battery is dead.
    I'm going to go look at it and if it starts and I can drive it a little I'll give it serious thought.
    Heck, for a $1000, the nav package alone would be worth it as mine has died again.
  8. kc5dlo
    kc5dlo Active Member
    266
    163
    DFW TX
    2021 Prius
    "How much can white paint cost?" When I was shopping for my 2014 model, it was $400.00 more for white.
    Sure it can be repaired reasonably well enough. How much cost and labor will need to be figured before making the decision. Maybe a flood damaged donor car could be found?
  9. Pluggo
    Pluggo Senior Member
    608
    532
    Folsom, Pennsylvania
    There was no airbag deployment, right? Whatever price the insurance offers to sell it to you for, ask if they would accept half that amount. In a worst case, you could buy another and and keep this one for a parts car.
  10. JC91006
    16,480
    8,397
    I couldn't tell from the front end that this car would have Navigation, so it must be a package 3. It's worth it for parts at $1000, the engine is worth more than that
  11. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    I get the feeling the OP really wants to buy the Prius and embark on the Resurrection process.
    Personally, that looks like a significant amount of damage.
    I wouldn't touch it.
    Likely has frame damage, I would never feel confident in it's safety.
    Johnny Cakes likes this.
  12. hill
    8,171
    i can buff that out . . . . .
    Given enough time & money? Yeah, everything is repairable. but not everything repairable can be done so for a reasonable rate.
  13. BZzap!
    BZzap! Senior Member
    1,607
    877
    From what I see in the photo, there is significant damage to the strut tower and frame structure. If you decide to purchase this car, I would only do it for parts. Even at that, you’ll probably have it in your garage for 10 year. Don’t bite off more than you can chew.
    JStrenk likes this.
  14. Johnny Cakes
    Johnny Cakes Senior Member
    1,015
    764
    Virginia, USA
    Do you know a television repairman?
    Raytheeagle and JC91006 like this.
  15. bisco
    49,437
    sounds like you have the know how and wherewithal. if your comfortable with tech stream and the service manual, go for it. the electronics will be the biggest issue.
    how many miles on her? what would it be worth pre accident, or post with salvage title?
  16. Slider2732
    Slider2732 Member
    64
    66
    Arkansas
    On some other forum there's a guy saying :
    "Some kid just side swiped my mates truck with a Prius. Might get it for cheap, here are the pics" :)
    A lot could be learned from taking the hood and any front/damaged plastics off.
    It greets the eye like a 5lb hammer, but then when looked at, I see what you're thinking. Perhaps a lot is cosmetic. That test drive would, and may have given most answers. If it's got bigger issues then i'd agree it's worth it for parts only, a wobbly front could easily cause a 2nd accident.
    Safest option if you fix it - let your daughter have your 2011 and you drive this one?
    JStrenk and Prodigyplace like this.
  17. JStrenk
    203
    101
    Ravenna
    PriusFenderandBumper.gif Good points brought up here.
    This guy is still waiting to hear from his insurance company.
    I'll try to go see it this weekend.
    I know they are cheap parts but $140 dollars for a bumper cover and passenger side fender.
    Does this type of accident happen so often that they put these two parts together in one package?
    [edit]Hmmm...Looks like I can't post a link to the bumper cover and passenger fender package.....[edit]
    #17 JStrenk, Jan 3, 2019
  18. heyphillip
    heyphillip Member
    131
    47
    Maple Shade NJ
    Damn looks like my 2010 which was totalled out. Old lady 87 years old just pulled right out in front of me last October insurance gave me $ 9,000 so I brought another one View attachment 163265 20181016_160100.jpeg
    Prodigyplace likes this.
  19. James1964
    James1964 Member
    177
    83
    Vashon Island, WA
    Delete this image from your phone and forget the address of this junk yard. This is kryptonite mate.
  20. egn83b
    egn83b Junior Member
    59
    Rarford nc
    Buy your daughter a none broken prius the hybrid parts alone are going to cost alot and its really not going to drive properly after being hit. Buy a prius with a dead battery and replace it. Much safer option for a young driver because she may get into an accident later and it might not be safe her if it get hit again.
    hill and JC91006 like this.
