Prius Smart Key Causing Check Engine Light
Discussion in 'Gen 2 Prius Main Forum' started by Jordan Duran, Mar 22, 2017.
  1. Jordan Duran
    Jordan Duran New Member
    The CEL in my 2009 Prius is on for the firs time since I've owned it and of course it's registration/inspection time. I took it to the local repair shop and had them read the code. I was told that my smart key was causing it and that it needed to be taken to the dealership for a replacement fob. I've never heard of a key throwing a code and in all my web searches on the subject I haven't come up with any examples of this happening to anyone else. This leads me to believe that perhaps the tech was mistaken in his interpretation of the code. Anyone have any thoughts?
  2. JC91006
    16,673
    8,518
    I hope you didn't have to pay that tech. Check engine lights are usually emissions related problems
  3. Jordan Duran
    No It was free.
  4. DonDNH
    DonDNH Senior Member
    1,711
    654
    Nashua, NH
    Four Touring
    Ask the local repair shop for the code they pulled, they may have either misread it or misinterpreted what the code meant. Some ODB readers don't report correctly for the Prius.
    Raytheeagle likes this.
  5. Jordan Duran
    Yes, you're right about the emissions, only in this case he said it was the key fob.
    The tech clarified that it was a code related to the vehicle's immobilizer system but didn't recall the exact code. Can anyone direct me on troubleshooting immobilizer system trouble?
  6. JC91006
    16,673
    8,518
    are you sure the light you have on is a "check engine" light? Can you post a picture? An immobilizer light has a key logo
  7. DonDNH
    1,711
    654
    Nashua, NH
    Four Touring
    I would replace the battery in the key fob and then test the voltage of the 12V battery. Many owners have reported odd problems caused by a failing 12V.
    Kevin_Denver and kenoarto like this.
  8. Jordan Duran
    Yes, It's a check engine light. The immobilizer light blinks when the car is off.
  9. JC91006
    16,673
    8,518
    check engine light is not related to immobolizer unit
  10. bisco
    51,155
    is the gas cap tight?
  11. ♡myPeeus
    ♡myPeeus Junior Member
    61
    57
    US
    Check the battery in your smart key. That was my issue when this occured
  12. TampaPrius.com
    TampaPrius.com Active Member
    461
    300
    Tampa, Florida
    95 % of all CEL lights I scan are
    P1121 Coolant control valve or
    P0420 Bad Catalytic converter
