Prius Smell Removal
Discussion in 'Gen 2 Prius Main Forum' started by mike1990, May 23, 2011.
  1. mike1990
    mike1990 New Member
    Dallas, TX
    Sorry but this maybe the wrong topic in here but I am trying to find out if anyone has found a solution for the smell in the 2008 Prius. I have read lots of posts but most stopped in December of last year, does anyone have any updates. I talked to the dealer and they said it was the seats are made from recycled material that make it smell like a horse barn then there are others that say its coming from the battery and its normal. I am new to all of this so if anyone can point me to a recent post I sure appreciate it. Thanks
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Perhaps you could give us a tiny hint as to how it smells - that would help immensely.
    Tom
  3. tf4624
    tf4624 Active Member
    526
    51
  4. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    23
    Maine
    "the smell in the 2008 Prius"
    The standard 'new car' smell is caused by off-gassing of the various materials (plasticizers etc.). Since this is a diminishing process, recycled material would be far less stinky than new materials. That also means that tomorrow's stink is still caught up in the materials today, and no cleansing of the air is going to get rid of it (though it could reduce any build up).
    As far as I can tell, the Prius is no more stinky than any other new car. Certainly, my 2007 only smells only a tiny bit like new car, and other smells are from what I put in it.
    If you are getting 'horse barn' smell, perhaps the previous owner used it to haul manure?
  5. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Yeah Prii don't have a smell any worse than any other car. And your car is old enough now to have 0 smell from off gassing. Whatever is causing the stink, is in the carpet somewhere. Take it to be interior detailed. And I mean $300-$500 real good inside deep cleaning detail.
  6. LIPriusFreak
    LIPriusFreak Can I haz JDM?
    449
    34
    Long Island, NY
    if your smell is trapped in the HVAC system, your best bet is to buy a can of OZIUM (vanilla or fresh scent), pop the hood, turn the car on and make sure vent is on high speed and spray the ozium into the intake ducts (by windshield)
    you should be able to walk back to the cabin and smell the ozium thru the vents. not only does this air out your HVAC system, it removes mold spores and bacteria that could be present.
  7. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    When I got my 2008, I kept parking in the HOT sun, kept the windows down, and in about 3 months my had pretty much outgassed itself. It however, did not smell like manure.
    A question that needs to be asked however is, Do you use the AC much? How much?
    What you might be smelling is the MOLD that is growing in the AC vents and on the heat exchanger coils. This is a common problem in all cars, some worse than others. I hardly ever use AC myself, but when I do, about 10 minutes before I arrive at my destination I will switch AC off, open outside air vent, turn fan on high, and open a window. That little sequence will effectivily dryout the air path. I stopped smelling "That Mold Smell" after I figured this little trick out.
    That could be what yer smellin! :D
  8. bisco
    49,334
    you've got the 'o' without the 'b'.
  9. mmcdonal
    mmcdonal Active Member
    666
    98
    16
    Columbia MD
    Yep, I think the manual says to run the hvac system with the AC off for a few minutes at least before you turn off the car when in hot weather, like in Texas or something. Also, try smoking cigars. Then that is all you will smell. :smokin:
    If it has a slight ammonia smell (as horse barns do) then try turning off the AC while the fan is going and you are pulling in outside air for a few minutes at least before you park.
  10. wmcbrine
    wmcbrine Junior Member
    56
    Laurel, MD
    FWIW, my Prius' smell (no, I can't describe it) seemed to go away once I started driving it regularly, and returned if I left it for too long.
  11. GSW
    GSW PRIUS POWER
    537
    74
    Jacksonville
    I wonder if the vent tube from the 12 volt battery has came off? If so, it might give off a rotten egg smell?
  12. qbee42
    18,058
    3,074
    Northern Michigan
    "My dog has no nose."
    "Then how does he smell?"
    "Terrible!"
    Tom
  13. bisco
    49,334
    mine got better when i traded in my girlfriend.
    ukiltmybrutha likes this.
  14. KK6PD
    4,003
    944
    118
    Wenn ist das Nunstück git und Slotermeyer?
    Ja!
    Beiherhund das Oder die Flipperwaldt gersput!
    followed by...
    "There were zwei peanuts, walking down the Strasse, und one was a salted... peanut"
    The British joke is laid to rest when "peace broke out" at the end of the war as countries agree to a Joke Warfare ban at the Geneva Convention. In 1950, the last paper copy of the joke is sealed under a monument bearing the inscription "To the Unknown Joke".
  15. mikewithaprius
    mikewithaprius New Member
    656
    103
    Rhode Island
    Ahh, interesting, thanks. I wonder if some "shtuff" builds up in my ducts, especially since I usually have AC and defroster off for hypermiling. There've been a few times I've come back to the car and been baffled at a slight garbagey smell, since I don't keep any trash in the car. I'll try running the fan some, and using a spray like was mentioned above.
  16. snijd
    snijd DIY or die
    243
    52
    PNW
    I've seen nothing in this thread about the infamous traction battery vent tubing odor. Sniff around the vent intake next to the back seat and see if you detect anything--like the manure odor. Other than removing the tubing altogether, there may be no easy fix. Also, some cars' battery fans become clogged, which might lead to an increase in odor problems. This could also lead to battery failure, according to Luscious Garage. Something to add to my maintenance schedule, I think.
    Hollywood Cole likes this.
  17. lextoy
    lextoy Active Member
    291
    131
    philadelphia
    2018 Prius Prime
    its the rancid rotting slime growing on you AC condenser.
    you need to run the fan a little bit every ride to keep it dry, if you use the AC then make sure to run the fan only after you tuen off the aC for a few minutes to dry it off.
    if you have the stinky smell now, you can get a foaming cleaner that goes up thru the AC drip tube under the car, it will at least clean off whatever buildup has grown in there.
    the vent tube might be clogged, so check it, if it is ther eis a pool of scummy water growing in the bottom of your AC system. this could also be the culprit.
    mine stunk a few times last spring, i started to dry the system out after running the AC run the vents on every ride, even on low.
    mine smeele dlike rotting garbage, or rancid gym socks.
    havent smelled it since.
    now my wife drove my mercedes all winter, of course has no clue how to operate the AC system or dry it out.. now it stinks.
  18. shamrock1
    shamrock1 Junior Member
    Bellingham, Washington
    I thought it was only my 2008 prius smelling bad but after reading here looks like Toyota has a problem with this year of Prius, we hardly even use the ac here, I do not have this problem with the 2010 Prius
  19. garglo
    garglo Member
    99
    45
    Port St Lucie, FL
    2020 Prius Prime
    2004 – 2008 Prius replacing the evaporator core. T-SB-0261-09 August 6, 2009
    HVAC Odor.
  20. Bill Lumbergh
    Bill Lumbergh USAF Aircraft Maintainer
    537
    NorCal
    This is an interesting thread. I used to work for a Honda dealer in OK, so I know about smelly A/C systems. Mine started smelling very acrid recently, but not the typical moldy smell I was accustomed to. I wondered if perhaps I was actually smelling a refrigerant leak because it only lasted a few seconds after initial system activation. It kinda made me think the leak was pooling somewhere in the evaporator container and I would smell it when the fan activated.
    I ran the fan on full blast and sprayed into the cowl intake with some disinfectant. It seemed better for a day or so, but I can still detect traces of the scent. I'll probably give the evaporator another blast.
    Oh, and the cabin filter is clean and dry.
