Prius sometimes lurches forward when I apply the brakes.
Discussion in 'Gen 3 Prius Main Forum' started by GreenTree11, Jul 29, 2011.
  1. GreenTree11
    GreenTree11 Junior Member
    Connecticut, USA
    Hello, everyone.
    I've had my 2011 Prius II for two months, and I love it. One little thing bugs me, however. I have noticed that sometimes when I apply the brakes, the car lurches forward a little bit. But I keep the brake pedal on, and the car does stop. Has anyone else experienced this? Is there something wrong with my brakes, or is this something that has to do with the regenerative braking?
    Thanks for any advice.
    GreenTree11
  2. fredthepostman
    422
    boothwyn pa
    Ditto !!!!!!!!
  3. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Many threads on this subject. Yes, it is the switching from regen to friction brakes. You will get use to it.
  4. GreenTree11
    Connecticut, USA
    Thanks, Spiderman. I checked some of the threads. You helped to put my mind at ease!
  5. GreenTree11
    Connecticut, USA
    Another reply to spiderman: This makes sense that it is switching from regen to friction brakes because it happens very rarely but when it does happen, I'm usually going downhill. What I probably feel is the switch over to friction brakes because of the hill. It usually lasts only a split second, but I do get a funny feeling in the pit of my stomach. Thanks, again. I appreciate your help!!
    :car:
  6. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    What mileage have you got on it?
    The brakes and brake rotors take take time to bed in. On a normal car this happens within the first couple hundred miles, but with the Prius it can take longer because the regen part of the brakes is used first.
    Once it's bedded in it should be much better and the transition/feel of the switchover will be much reduced.
    The European Prius have softer pads and rotors and this problem doesn't appear to be as much of an issue over here. The downside is that our brakes don't last as long - even on a Prius.
  7. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Actually the switch over happens quite a bit... every time you stop. Once the speed drops to 7 mph the friction brakes take over. Or if you have excessive battery charge regen drops out and friction brakes and or engine braking take over. Or if you are braking and you hit a bump in the road the ABS will cause the switch over.
    I will say that I do leave a lot more room between me and the car in front than on any other car I have owned.
  8. revhigh
    revhigh MPG Enthusiast
    986
    141
    PA - Pocono Mountain Area
    Although it may 'feel' like it ... it's definitely NOT speeding up at all ... it's just the transition between regen and friction brakes has been mentioned. Just ignore it. In 11,000 miles ... I've noticed mine has done it maybe 5 times ... usually on bumpy terrain when mine has done it.
    No big deal really.
    REV
  9. GreenTree11
    Connecticut, USA
    Hello, GrumpyCabbie. My Prius has only about 1800 miles. It's still a baby. By the way, Yorkshire looks nice. Hope to visit some day!
  10. GreenTree11
    Connecticut, USA
    Hey, spiderman, you're right. I have noticed that little lurch, or switch over, when I hit a bump in the road. And I'm also learning to leave a lot of room between me and the car in front of me! Sometimes I think I'm not driving a car but, rather, a computer on four wheels. It's a great car. After two months and about 2,000 miles, I know that I have a real cream puff.
  11. GreenTree11
    Connecticut, USA
    Thanks, Rev. As you said, I notice it when I'm on bumpy terrain. Also going downhill. But in a little over 1,800 miles on my new Prius, I've noticed it only two or three times. Thanks for putting my mind at ease.
    GreenTree11 :bump:
  12. SpikeVFR
    SpikeVFR New Member
    221
    SF Bay area, CA
    Are you feeling a change in the braking power or a lurch forward. Two very different things. If your car is going forward at a faster rate when you press the brake, that is a problem. A serious one to me. A change in braking power, however, is not.
  13. GreenTree11
    Connecticut, USA
    I'd call it a change in the braking power. And it lasts only for a split second.
  14. revhigh
    986
    141
    It just 'feels' like it's lurching forward because your mind is expecting braking, so when the momentary switchover occurs it 'seems' like the car is speeding up or like the brakes have failed, when in reality ... neither has occurred. It's just an anomoly of the regen/friction brake system. If you've never experienced it, it CAN be a little disconcerting.
    REV
  15. spwolf
    spwolf Senior Member
    3,156
    440
    Eastern Europe
    my buddy hates that when he goes over speedbumps, his passat cc activates dsp and brakes his wheels slightly (at slow speeds)... electronics!
  16. Mendel Leisk
    38,207
    Might be related: I've noticed when backing out of our garage, just after start up: one in a while (not that often), the brakes are very touchy. It's near impossible to modulate braking pressure: they're either on, and near locked, or off. No in-between.
    Goes away as soon as I get out on the street and underway. Computer?
  17. swoodchuk
    swoodchuk Junior Member
    Bel Air MD
    I have a 2010 prius with almost 8000 miles on it and I have experienced the same thing. I think its ok and the braking system is just syncing with the electric motor and the engine. Mine does it at speeds less than 40 so that could be a speed that the car decides on electric or gas to kick in at.
  18. Sporin
    Sporin Prius Noob
    576
    293
    Vermont, USA
    I notice it every so often, as stated before, it's just the switch from regen braking to friction braking. I tend to only notice it when I'm slowly coming to a stop and hit a slippery spot (ice, manhole, etc). Very very rare.
  19. qbee42
    qbee42 My other car is a boat
    18,058
    3,073
    Northern Michigan
    And it contains the town for which my family is named:
    [ame=http://en.wikipedia.org/wiki/Wetherby]Wetherby - Wikipedia, the free encyclopedia[/ame]
    Tom
  20. LeadingEdgeBoomer
    289
    29
    New Mexico
    These respondents to the OP have been extremely polite. My advice: the search function here is your friend to forestall repetitive inquiries.
