Prius Stereo Volume not Working
Discussion in 'Generation 1 Prius Discussion' started by Kristy, Jun 11, 2013.
  1. Kristy
    Kristy Junior Member
    39
    2001 Prius
    I
    My Gen 1 stereo volume doesn't work at all anymore. Of course this happens when someone who wanted to buy it is checking it out, and we leave for Brazil next week. Everything on the display is normal, the cassette player isn't making weird noises, but no radio or ipod hookup volume whatsoever. I'm worried someone who was testdriving it last week might have been pressing random buttons, but we've tried pressing most of 'em and still no dice. But also, it has been very humid in west LA this past week and I was reading on another priuschat thread for a Gen 2 with similar issues this might have related to it, but it seemed uncertain. Is this what happens when speakers die? Anything I should try? Thanks for your time!
  2. ChapmanF
    15,459
    Hi Kristy,
    When you say your volume doesn't work, do you mean you're not getting any sound at all, whether you turn the knob all the way up, all the way down, or anywhere between?
    In a quiet place, if you turn it all the way up, can you hear any buzz or hum through the speakers? If you open the driver door with the shifter in D, do you hear a bong?
    -Chap
  3. Kristy
    39
    2001 Prius
    I
    Thanks for your time! No, no sound whatsoever, regardless of where I turn the know. I did turn it all the way up in a quiet place, and no buzz or hum at all. And no bong with shifter in D.
  4. Kristy
    39
    2001 Prius
    I
    Er...knob, not "know."
  5. bwilson4web
    15,512
    Were you testing it with a cassette tape?
    The reason I ask is I use a cassette tape adapter and occasionally I have to hit "tape" button to get audio. It is as if there are modes that have to match to get audio. I don't use the radio nor the CD any more.
  6. Kristy
    39
    2001 Prius
    I
    I did, but I also switched it to radio, and while it looked like it was getting radio stations/switching, no volume at all.
  7. ChapmanF
    15,459
    I've never seen a posting about a dead radio before, but maybe you could be the first.
    If you unplug R2 and R3 at the back of the radio and then touch pins of the plugs (on the wire harness, not the sockets on the radio) with some wires on a small battery (for example AA) you should be able to make clicky sounds from the speakers:
    R2 pins 2 to 6: left rear, 1 to 3 right rear
    R3 pins 2 to 6: left front, 1 to 5 right front
    If you can make the speakers click I'll bet the output amp in the radio is kaput. I'd be really surprised if you couldn't make any of the 4 speakers click - some strange simultaneous failure or wiring problem? Unless - some previous owner added an aftermarket amp between the radio and speakers, and something is wrong with that.
    -Chap
  8. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    954
    720
    Boulder Hybids, Boulder, CO
    Be careful with Gen1 dash panels, lately they all seem to crumble when taking apart to access the radio. The plastic is old and brittle, especially in dry climates.
  9. ChapmanF
    15,459
    Good point. At one time I found I could pretty easily reach the plugs on the back of my radio just by removing the glove box and reaching over. IIRC the sockets are all on the side of the radio near the glove box opening, except the antenna cable socket which is over in the far corner.
    -Chap
