Prius system goes dead when pressing stop/start butto
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Blacks1, Apr 28, 2011.
  1. Blacks1
    Blacks1 New Member
    New Zealand
    I have a gen2 2007 prius (right hand drive here in New Zealand). Problem I am having is [INTERMITTENT]when pressing the ignition button to turn off the car. When I press the button the system completely shuts down instantly and rather roughly and nothing is active (the Key is still in). I then remove the key and the system starts up! I then press the button to stop the system, put the key back in and restart it. It then works fine - until the next time. Clock resets itself as does the climate controls. Not sure what to make of this. I have just recently replaced the 12v battery in the boot.
    PS. Forgot to mention that when the system goes dead, if I fold down back seat and thump the floor panel above the battery under the seat the system goes on?? Any clues. Will take it to mechanic as soon as he gets back from holiday!@##
  2. nerfer
    nerfer A young senior member
    2,505
    233
    28
    Chicagoland, IL, USA, Earth
    Yeah, good luck with that!
    Sorry, but I definitely have not seen that behavior, sounds like a loose wire or intermittent short somewhere, could be tough to find that one, without going thru the connectors one by one.
  3. Patrick Wong
    18,200
    6,471
    If the clock resets, that is a clue that the system lost 12V power. You might start by verifying that the connections to the 12V battery are clean and tight, and that the 12V battery (although new) is in good condition. If the battery and cabling are good, then it is likely that you have a wiring harness problem in the dashboard.
  4. Blacks1
    Blacks1 New Member
    New Zealand
    Thanks This has been most helpful. I will check it out as you suggest:)
