Prius tackling steep hills
Discussion in 'Gen 2 Prius Main Forum' started by dani1166, Jul 21, 2010.
  1. dani1166
    dani1166 Junior Member
    25
    Australia
    Hi i just recently bought a 2007 prius and have notices going up my driveway is a bit of a challenge. My driveway is steep and as you know the petrol engine shuts off when you brake. so as soon as i accelerate to go up the driveway it switches over to the petrol engine and revs loudly leading to a skid up the hill. Is there a way to overcome this? it still does it even if i accelerate gently up the hill and sometimes a little orange light with a car skidding on it lights up. If anyone knows a way to prevent this please let me know. thanks
  2. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Is the traction control kicking in and cutting power? The skid light blinking is indicative of that.
    I've never had a problem w/this but, IIRC :confused: some suggest backing up.
  3. dani1166
    25
    Australia
    The light blinked a few times but the power didnt cut off...
  4. Patrick Wong
    18,200
    6,479
    1) Check the condition of your tire tread depth (especially the front tires) and buy new tires if needed to improve traction.
    2) If your tires are in good condition, then try backing up your driveway if practical. When the front axle is lower than the rear axle, vehicle weight will shift to the front axle, thus improving traction.
  5. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    The situation you describe is not related to the ICE (petrol engine) starting, other than the part about hearing it run. What you are experiencing is Traction Control, which kicks in when either of the front tires lose traction. It works like ABS in reverse, cutting power to the drive wheels when traction is lost.
    To avoid this problem you have three four options:
    1) Get better tires.
    2) Pave your driveway.
    3) Trade your Prius for a Jeep.
    4) Move to a house with a flat driveway.
    #1 seems like the best option.
    Tom
  6. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Have you tried switching the car into EV mode and driving up the slope slowly this way?
  7. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    Gen II doesn't have the option of switching modes.
  8. qbee42
    18,058
    3,074
    Northern Michigan
    ...in North America. In other regions the Gen II shipped with the EV switch.
    Tom
  9. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    301
    Northwest VT
    2018 Prius Prime
    Sounds like most any car trying to go up a steep snow or loose gravel covered hill :) Did the OP's prior vehicle slip and spin on the way up and what kind of vehicle was it?
    With no other information, I also vote for the tires.
  10. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    I read that the poster is based in Australia and assumed would have a RHD Prius which should have the EV switch. ;)
  11. qbee42
    18,058
    3,074
    Northern Michigan
    Well that explains it. The OP probably has a roo stuck under his tyres.
    Tom
