Prius tire chains for snow any updates?
Discussion in 'Gen 2 Prius Main Forum' started by problemchild, Nov 6, 2008.
  1. problemchild
    problemchild New Member
    429
    36
    I looking through the old thread (2005) and there does not seem to be any conclusion. I was wondering what everyone is using for the snow. I see that any gap in the tire traction device could cause the tire to slip and shut off the engine. I don't want to be on an .00000001 uphill climb and have my car turn off. Toyota really blew it with the engine shut off design. Last thing you want to have on ice is the engine lurching on and off.
    So...........
    Are there any reasonably priced easy on/off designed tire traction devices (snows chains etc) out that everyone is happy with?
  2. Ct. Ken V
    Ct. Ken V Active Member
    535
    57
    Bolton,CT
    problemchild,
    The "tire traction device" you refer to isn't a stand-alone, add-on option that you can take away or add on or turn off or on. It is simply Toyota's version of traction control that's built into the PSD (transmission) to protect the internal parts from over-spinning & ruining your $9,000 transmission. The traction control does NOT turn off your engine, but instead cuts power (through the transmission) to the wheels so that they don't spin again making you lose traction worse (which could cause some serious results). It makes the wheels turn unbearably slowly which should allow you to regain the traction you originally lost.
    There were more problems with the '04's & '05's since the traction control was apparently programmed to be very aggressive in stopping the wheel spin. Toyota is supposed to have re-programmed the traction control to be less aggressive since the 2006 model, so with your 2008 Prius you shouldn't have as much of a problem as those early posters in that 2005 thread. If you're still afraid or you do have problems of your own in this regard, then I suggest you change to a better all-season tire (or snows or studded, if you must), but you will lose some MPG by doing this.
    Ken (in Bolton,Ct)
  3. atroader
    atroader Engineer
    39
    Atlanta, GA
    If you're able to get a little traction with your tires, carefully two-footing with slight brake pressure will keep the tires from breaking traction too quickly to kill the engine (engine will be used for torque to overcome the brakes).
    This worked for me on some steep gravel hills in the mountains last spring.
    Of course, dont do this for too long or you'll heat the main mg significantly. (ok for a min or so)
  4. problemchild
    429
    36
    Im asking about snow chains or any other TIRE traction device. I understand how the engine kill thing works and I understand why.
  5. problemchild
    429
    36
    Snow chains........
  6. ChapmanF
    15,411
    Anybody tried out the AutoSock? It looks sort of promising.
    -Chap
  7. Presto
    Presto Has his homepage set to PC
    1,326
    24
    Vancouver, BC
    I've gone the regular tire chains route and had good success with them, other than the pain of installing them. Back in that day, I was also looking at Go-Claws, but then the snow melted. They tout quick installation and removal.
    This year, I'm going the winter tire route with X-Ice2, which will be my first ever set of winter tires. They should rock.
    EDIT: I also considered the Autosock, but I decided I didn't want something that looked like packing material for shipping.
  8. ChapmanF
    15,411
    :) But maybe you could use them as packing material while carrying them around in the back when not in use. Try that with a set of chains....
    -Chap
  9. problemchild
    429
    36
    Well I bought the tire cable chains from vulcan tire for 69.00.
  10. bnettles
    bnettles New Member
    What does the owners manual say about chains? I got the Compact Grip by RUD. There is a movie on installing them at tirechaindealer.com. I have to say, they are very easy to put on.
  11. infogeek
    infogeek New Member
  12. infogeek
    infogeek New Member
