Prius Torque output?
Discussion in 'Gen 2 Prius Main Forum' started by Dolce_Vita, Jul 21, 2011.
  1. Dolce_Vita
    Dolce_Vita Member
    228
    25
    Sydney, Australia
    There seems to be a bit of black magic involved in combining the torque figures of the HSD hybrid :s I can't find the max torque output of either a Gen 2 or 3 on the internet, only the individual output for the MG2 and ICE.
    Does anyone know what the combined max torque figure of the gen 2 Prius is? (for comparison to other cars[Diesels!])
  2. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
  3. Dolce_Vita
    Dolce_Vita Member
    228
    25
    Sydney, Australia
    That Prius on the Dyno is so out of place! haha! I wonder how much of a hit the average MPG took?
    It's still frustrating that there's no definitive combined petrol electric max torque output in NM or pound feet to be found anywhere?
  4. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    511
    63
    With the power and speed given above and the tire diameter you should be able to calculate the torque at the wheel easily. The rest is left as a homework assignment. ;)
  5. Sezy
    Sezy Active Member
    431
    229
    37
    Saint Charles, Missouri
    2020 Prius Prime
    Got a dyno for fun at a car show. No rear seats and a drop in K&N filter at about it for power mods. Had the car in base with traction control off. Yes lots of people were laughing,making solar panel jokes,back to the future jokes, and so on... Until they saw the read out and were kinda impressed or curious,well for a prius.lol:LOL: Pared next to the other cars that got dyno and popped my hood. Actually had a few people check the car out. :)The guy driving for the dyno knew very little about the prius/how to operate one. The dyno was having trouble they say because I have a CVT transmission and the machine reads better knowing what gear the car is in. Any ways here are the results.
    RUN#1
    RUN #2
  6. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    B mode is for braking down long hills, it makes no difference in acceleration. B is valuable in the Rockies.
  7. Sezy
    Sezy Active Member
    431
    229
    37
    2020 Prius Prime
    I shall test your this at my next drag race. Do specific runs in Drive and one in Base. Might be a month or so.
  8. ChapmanF
    17,326
    For Gen 2, page MO-20 of the 2004 New Car Features Manual (see techinfo.toyota.com) has got what you're probably looking for: performance curves for the ICE by itself, MG2 by itself, and for the combined system versus vehicle speed. The combined system torque looks to be just a shade under 500 Nm, from dead stop to just under 30 km/h, dropping off gradually above that speed.
    The theoretical way you would get there is by seeing that the power-split gearset in the transaxle always sends 72% of the ICE torque straight to the output. The other 28% always spins MG1, creating an electrical alternate path that has to rejoin via MG2 (and therefore MG2's maximum torque rating already includes it). So take the 400 Nm max torque for MG2 and add the ICE's 111 Nm max times .72, or about 80 Nm, for a total of 480. That's pretty steady over the first 30 km/h of vehicle speed because just by varying the allowed MG1 spin rate, the computer is able to keep the ICE near its best RPM range while the car accelerates.
    These figures are ahead of the final drive, which has different ratios for the different generations and models. Gen 2 is 4.113 (from the same manual, page AP-2).
    I don't have the 2010 New Car Features Manual handy, but you can surely find the equivalent information there. You'll notice that with Gen 3 they added a reduction gearset between MG2 and the familar power-split gearing, so the raw MG2 torque has to be increased by that factor before adding 72% of the ICE torque (and then adjusting it all for the final drive ratio).
    -Chap
  9. dolj
    dolj Senior Member
    8,209
    4,180
    Wellington, New Zealand
    D = Drive
    B = engine Brake.
    There should be no difference in acceleration or torque developed in either mode; only the rate at which it decelerates with your foot lifted off the go-pedal and the amount of energy captured (regen) into the HV battery (more in D; less in B).
    #9 dolj, May 16, 2015
    JimboPalmer likes this.
