Prius trouble
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Cjeigh, Feb 11, 2014.
  1. Cjeigh
    Cjeigh Junior Member
    45
    Winnebago, IL
    Ok, so I had the IM replaced today in my 2010 III due to CEL illumination, will post error code and part # later. Prior to taking it in, my "Oil Maintenance Required" came on upon start up, so I had them do that while I was there getting the IM replaced. Then the service tech comes to me and says, "Your back brakes have 0 pads and you need new rotors, a front end alignment and possibly new tires."
    I just bought this car, Toyota Certified, on December 12, 2013! Sure, I've put on 5,000 since then, but geez - b.s.
    I bought the car from another Dealer than which I had it serviced, due to location - soooo, of course I call the Dealer where I bought it and let them know what I was just told - no back brakes basically - and they say, "I don't believe it." So, I make an appt. to have them look at it in a day or so, due to my availability. Well, prior to that, I'm having Farm & Fleet inspect the brakes and I'm getting a written report from them also. If the Service Dealer is incorrect, then I won't make the drive to the Selling Dealer and won't use that Service Dealer again! If the Service Dealer is correct, then I'm going to the Selling Dealer and making a fuss about the supposed Toyota Certified Vehicle they sold me.
    Any other hints, ideas. I don't like confrontation. I just wanted a reliable vehicle and I thought that is what I was getting when I purchased this 2010 Prius with 37,000 miles.
    Wow, was I had, or what? I'm trying to remain calm and confident that if someone was at fault, it will be taken care of without any $ from me. I paid for the car, no negotiations on their part, whatsoever.
    Thanks, in advance if you have a reply : )
  2. KiwiAl
    KiwiAl Junior Member
    146
    New Zealand
    Hi Cjeigh,
    Yeah, I know the feeling, hopefully, it will evaporate soon.
    I doubt you were had, but the jury is still out. If the mileage is genuine, it's pretty unlikely that you need any of the alleged parts. You can check a lot of it yourself.
    If you look over the car closely, does it look as if it's done a lot more than 42,000mi? Look at the wear of all the carpets; the foot pedals (brake pedal especially, for wear to the rubber cover pad); the door sills for lots of scuff marks from people getting in and out; the boot (trunk, cargo bay) carpet for dirt, wear, etc; the plastic covers around the footwells (for scuff marks etc). Look at the areas by the door hinges on all doors, for dirt and dust. At 37,000mi, I wouldn't expect to see a lot of wear and tear or dirt/dust etc in any of these areas. My car has done 85,000km (53,000mi) and only has obvious wear around one door where some furniture or something scraped it, and the driver's side floor mat is starting to look worn.
    You can also look at the brake pads and discs (rotors) yourself, if you are willing to get down on your knees. The discs are easy to see through the spokes on the front wheels. They should be relatively smooth all the way across, without any visible grooves or gouges running around the circle.
    If your pads have completely worn out (extremely unlikely at 42,000mi, IMHO), they will be down to the steel backing plate. Usually, you'll hear a squealing sound - like a high-pitched eeeeeeee sound from the wear limit tell-tales when rolling with the windows down (I have no reason to believe Prius' don't have these, most cars do these days), long before your pads are worn out. And, usually, before they wear out completely, you'll start to hear a rough grating, grinding sound when you brake hard. This will get progressively worse, and once that starts to happen, damage to your rotors will happen very quickly. If that has happened, you will probably need new rotors, but your disks will also have obvious grooves and gouges. It's pretty unlikely that you wouldn't have noticed this noise when braking. Being a Prius, I really doubt the brakes have got to this point already.
    For some reason, I can no longer post photos or I'd show you what to look for to assess brake pad wear, but if you are happy to take one of the front wheels off, it's much easier to see. The front brake pads live inside the brake caliper. (Note, there are brake pads on both sides of the rotor, so check pads and rotors on both sides.) They have steel backing plates that the friction pads are bonded to. The friction pads contact the face of the disc (rotor) inside the caliper. The friction area is less than the area of the backing plate, and the backing plates overhangs the pads at each end. The clearance between the face of the rotor and the face of the steel backing plate reveals how much pad you have left. Expect at least 1/8 inch of clearance as a minimum (time to replace the pads), but usually more than 1/4 inch of clearance. If there is no clearance at any point, your pads are worn out, and your rotors probably ruined.
    If that is the case, the dealer has probably cheated you. I don't know what rules govern car dealers in the US, but find that out before you go back.
    Does this help?
  3. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Go get em tiger! Sounds like a lot of BS to me. Think you are doing the right approach at this point though. Keep it up.
  4. Cjeigh
    45
    Winnebago, IL
    I agree with you on the at "42,000 miles"? No sound from brakes. I'll pay $15 for a 2nd opinion. Trying not to think about it, just had to vent. Thanks. I'll check out the car selling laws. I've printed some stuff from the Toyota Website as far as Toyota Certification Vehicles already. I mean, if it doesn't mean anything, they ought not use the phrase.
  5. bisco
    49,444
    what is an IM? was that covered under the certified warranty? it's pretty difficult to sell a car with forged mileage these days, especially for a dealer. i'm sure the brakes are fine, although, there have been reports of early failure due to road salt. but that should be covered as well. as far as an alignment goes, how do the tyres look? how does the car track on the highway? how many miles on the rubber? all the best!(y)
  6. Tony D
    Tony D Active Member
    468
    132
    Dublin, Ireland
    Plenty of good advice from the man down under!
    Keep us posted of any developments
  7. Bingee
    Bingee Member
    210
    62
    Michigan
    Get a second opinion , ask who original owner was , check to see what milage they had
    A large Cadillac dealer in west Michigan, got busted some years ago turning back
    Odometers .... Good luck
  8. bisco
    49,444
    intake manifold?
  9. KiwiAl
    146
    New Zealand
    Yup!
    There's a Glossary here but it's missing a few terms, (like UOA, which I believe is Used Oil Analysis) and is wrong on a couple. There might be another one somewhere else here.
  10. Cjeigh
    45
    Winnebago, IL
    Manifold Part # 37054 was put in.
    My trusted, long time mechanic did check out the brakes and sure enough I had to get pads, rotors and a caliper boot repair kit. After driving my Prius now, I can definitely tell, "I had no rear brakes, all this time!" I'm pissed. I wrote a letter with accompanying work orders/invoices to Toyota Motor Sales in Torrence, CA and sent a copy of the letter to my salesperson. The local dealer also noted that I need 4 new tires and a 4 wheel alignment.
    My sister-in-law gets great results when she writes letters, so I thought I would try it. You know, if I would've purchased from an independent seller, I could see this happening, possibly; but from a dealer who Certified the vehicle - not fair at all. I'll let you know what happens.
    Thanks for your posts, as always.(y)
  11. Fore
    Fore Don't look back!
    494
    107
    That's why people here call them "STEALERSHIPS"
  12. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    In reality- "Toyota Certified" seems to mean it was purchased from a Toyota dealer and you do get some sort of warranty if you have a major problem. From what we've seen on PC slip by the "certification" inspection- it seems that some dealers apparently do the inspections from inside the sales managers office.
    dorunron likes this.
  13. KiwiAl
    146
    New Zealand
    DANG!!! I bet.
    Weird that there was no noise at all. They must have completely rusted / seized up... Not even any braking action at all.
    Extremely Dangerous, actually. This may be a point you ought to focus much more on. Not only a shoddy, sub-standard "Toyota Certified" vehicle, but a highly unroadworthy and downright dangerous one at that.
    In a severe Emergency Stop, you would almost certainly have spun completely out of control, when the back of the car tried to overtake the front because there was nothing slowing it down, and no way that the VSC system could have done a blind thing. I'm sure others here would confirm this probability. Who knows what death and mayhem that might have caused? Imagine spinning out of control and wiping out a couple of young kids on the sidewalk!
    Toyota Japan needs to hear about this, if you ask me. They certainly don't want their name further sullied by shonky American Toyota "Stealerships".
    In my country, your car would fail its 6- or 12-monthly vehicle safety test and be legally Off the Road until it was fixed and retested. Everyone here complains, but we should be grateful for the compulsory safety checks. You don't have those in the US?
    They fit rear brakes, and go to a lot of trouble to make sure the wheels don't lock up under braking, for a very good reason. And here, we/they insist that they work. Every car (that goes to a proper testing station) goes through a full rolling brake test, both front, both back, and parking brakes. Braking Force readout and %age efficiency recorded.
    Why don't you name some names in this thread? Which Dealership sold you the car? Are you saying Toyota Motor Sales in Torrence, CA sold it to you? What is their physical address?
    What is the name of the Sales Manager, and the Salesman who sold you this mobile safety hazard? Have they responded to your letter?
    Do you have the old parts? How about a Mechanic's Report on the state of the brakes and the repairs required? They might be able to hide your letter, but they won't like all the sordid details posted here, I'm "fairly sure"! ;)
    Keep us posted!
    P.S. Others here report similar rear brake issues on the Gen 3... I'm starting to quite like my G2 with its old school, rear drum brakes...
    Google prius gen 3 rear brakes
  14. css28
    css28 Senior Member
    1,566
    442
    Suburban Detroit
    To address just the smallest part of your big post, safety inspections along with titling and registration are done at the state level and thus are totally inconsistent.
    When I was growing up in Massachusetts (in the 60's) there were safety inspections required every 6 months (spring and fall). Where I live now there are no safety inspections and no emissions tests.
  15. Cjeigh
    45
    Winnebago, IL
    I will see what their response is before I name names. I'm certain, after speaking with the dealership's service advisor, who also was in disbelief about the rear brakes being 0%, that they will claim "it's not their problem", "our inspections showed . . . ", which is why I wrote to Toyota Motor Sales, USA, Inc.
    If I don't get a positive response, I will certainly warn many future buyers of automobiles at this dealership of my purchase experience from them, from all the sites I went to when finding my Prius.
    I'm not going to lose any sleep over it. It is what it is. It's up to Toyota now to determine what I do. Of course, I did not threaten them to post negative reviews. Obviously, I looked at the reviews of the dealership that I purchased from before making my purchase and was confident that I was making the right choice.
    My trusted mechanic told me that he would talk to anyone about the situation, if need be. He also mentioned that with the rear disc brakes, there is no cover (like in rear drum brakes) to keep the salt and crap out of the disc system. Sounds like something could be improved in that scenario. And if that happens because of my situation, (as well as others, I'm sure) well then my efforts will be worthwhile.
    I continue to drive my Prius as if I am fully protected and getting the BEST mpg that I can! Especially since gas is now at $3.68 around here. Geez-uz - more peeps are going to be wanting this vehicle!
    Thanks for your comments, as always.
    PriusGuy32 likes this.
  16. Cjeigh
    45
    Winnebago, IL
    Finally called Toyota Motor Sales back today, I WAS in a good mood. I get a big fat $0.00 for the rear pads, rotors and caliper repair kit, $423 that I had to spend after owning my Toyota Certified Vehicle for 5,000 miles, mileage @ 41,000. I'm a little pissed right now, but sure I'll get over it. I know, "breath deep, breath deep"! I am pleased with my recent 57.3 mpg miles tho : )
  17. Cjeigh
    45
    Winnebago, IL
    I bought this 2010 Toyota Certified Prius from Elgin Toyota, from Thomas Licata. I never received a response from him, only Toyota Motor Sales, U.S.A. - "those are wear and tear items, not covered". Even Walmart told me that shouldn't happen with only 40,000 miles.
    Any suggestions on how to get Toyota to at least help pay for that repair? My letter didn't work. I did go to Dealershipraters.com or something like that, but I would like to do more.o_O
  18. bisco
    49,444
    did you get a written warranty with the purchase?
  19. Bingee
    Bingee Member
    210
    62
    Michigan
    I didn't read all the posts on this , but what in writing makes purchasing a TOYOTA CERTIFIED
    TOYOTA a big selling point ?? Must be something in writing that might look like what's covered
    How long , hand shakes and free coffee don't do it ,,,,
  20. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    I feel sorry for you. And it's just another story that makes me doubt even more the fabled Toyota Customer Service and Support that use to exist.
    Sure those are all wear and tear items..BUT you've only put 5000 miles on the vehicle since you purchased it.
    And if you go to Toyota's own "Certified" program webpage, Toyota proudly proclaims how every certified vehicle comes with a 160 pt inspection...a 174 point inspection for Hybrids. They actually word it as a reconditioning and inspection...
    So if I was writing a letter, or launching an argument my question would be, how does a vehicle that supposedly underwent a "reconditioning" and 174 pt inspection end up with all the problems yours already has?
    So Toyota's certification program Okays vehicles as passed and "reconditioned" that are less than 5000 miles from having no brake pads? And that need new rotors?
    Shouldn't those of easily been part of the inspection...and if that close to needing replacement, been replaced?
    I think so...and it's too bad Toyota isn't backing you on this.
