Prius upgraded lights and fogs
Discussion in 'Gen 3 Prius Accessories and Modifications' started by YukYukLee, Jun 26, 2015.
  1. YukYukLee
    YukYukLee Junior Member
    58
    17
    Boston, MA
    Just added xenonsupply 4300K HID kit and some fogs from eBay not the best but still works let me know what you guys think! Also replaced the passenger headlight assembly because for some reason there was a burnt mark in the corner.
    51,154
    really sharp looking, well done!(y)
    YukYukLee likes this.
  3. 4rpr15
    4rpr15 Senior Member
    1,056
    375
    WI
    How do you like the xenon depot Philips 4300k, why didn't you go with the 5000k? Was it hard to install?
    iPhone ?
  4. xliderider
    xliderider Senior Member
    8,056
    3,223
    Honolulu, HI
    I think you just made a poor "upgrade" that will shine a lot of glare into people's eyes. The cheap eBay reflector foglights don't really have any effective cutoff to prevent glare, or stay light from shining high up. Installing HIDs into them makes the problem even worse. :(
  5. YukYukLee
    58
    17
    Boston, MA
    I went with that because the site said this was the most brightest in terms of length but i wish i did go 5k 4300k is kind of piss yellow lol.
    Funny you said that because I compared this to the factory fog lamps and there was no difference. I only use my fog lights when its dark and rainy. Unlike some people that think leaving their fog lights on at night gives better vision which is totally false.
  6. 4rpr15
    1,056
    375
    WI
    Did you know it color shifts to 4700k after 100 hours?
    iPhone ?
  7. YukYukLee
    58
    17
    Boston, MA
    I have no idea... I should check to see lol
  8. xliderider
    8,056
    3,223
    Honolulu, HI
    I may have been hasty in my reply earlier. Did you install HID in your lowbeams and regular halogens in your foglights? If that is the case, then I apologize.
    If you installed HIDs in your foglights, then my previous post stands.
  9. YukYukLee
    58
    17
    Boston, MA
    My hids are for low beams. I don't see a reason why anyone would put hids for fogs when the fogs will reflect the light back at you lol. My fog lights are halogens. No hard feelings lol
  10. 4rpr15
    1,056
    375
    WI
  11. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    I have 3K HIDs in fogs on 2 cars and they work great. Yellow doesn't reflect back and doesn't blind as much, plus fog lights generate very wide beam so the density of the light is still low.
    This had worked very well in dense fog in mountains. Anything less would have been useless. But then again some only install fogs for show, not for actual help
  12. YukYukLee
    58
    17
    Boston, MA
  13. 4rpr15
    1,056
    375
    WI
    Top notch I had them on a 4Runner I just sold.
    iPhone ?
  14. YukYukLee
    58
    17
    Boston, MA
    good because i just ordered a set lol
    4rpr15 likes this.
  15. 4rpr15
    1,056
    375
    WI
    Did you ever consider h11 Morimoto Elite hid's?
    iPhone ?
  16. YukYukLee
    58
    17
    Boston, MA
    Are we talking about headlights or fogs? Because the ones I just ordered was for fog lights lol
  17. 4rpr15
    1,056
    375
    WI
    Yes for fogs those led's are great. Why do our headlights have the halogen light and the small light above it? When you put in the hid's did it change both of those lights or just the halogens?
    iPhone ?
  18. YukYukLee
    58
    17
    Boston, MA
    when I changed my low beams to HID's I changed the top lights to LEDs. I am assuming these lights above are for looks?
  19. 4rpr15
    1,056
    375
    WI
    Do you have a pic?
    iPhone ?
  20. Boston Jim
    Boston Jim Active Member
    202
    148
    If I understand the question, those are the parking/ running lights.
