Prius V 2012: I want a new radio that has modern technology!
Discussion in 'Prius v Audio and Electronics' started by ErikaM, Feb 4, 2022.
  1. ErikaM
    ErikaM Junior Member
    San Francisco
    I have a Prius from 2012 and it is really hard to use Siri with it, and one day I'm going to kill myself on the road trying to use spotify or get siri to make phone calls.
    I want my car to work easily with Apple Car play or something. It does not.
    I called Crutchfield and they told me my model of radio cannot be upgraded or switched out at all. Something about that it has parking assist?
    does anybody know a work around?
  2. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,424
    2,393
    Taylors, SC
    The only 4G enabled radio came with the 2017 Prius v, which is the last model year offered. All other Prius v model radios use the same older technology. If you can find one in a wrecking yard, it won't be cheap.
  3. gromittoo
    gromittoo Active Member
    719
    288
    philadelphia
    2013 Prius v wagon
    Don't bother using Toyota Entune! It is the worst software ever written! You can use your audio system just fine without it. I have no problem getting Google Assistant to make phone calls on my Head unit for me. "OK Google" and "Phone Home" just works.
    The MultiFunction Display units from a 2015 or 2016 Prius V (Faceplate ID 510057) are a substantial upgrade from the 2012 to 2014 MFDs (Faceplate ID 57011), and are not that difficult of an upgrade. The upgraded unit can be found on eBay for ~$225.
    I don't know if anyone has tried to put a 2017 MFD (Faceplate ID 510165) into an earlier Prius V.
    Don't bother looking at MFD units that are not from a Prius V. Prius C and regular hatchback Prius units won't fit in a Prius V.
    icyrius, TheTewks and jzchen like this.
  4. wheelz1980
    wheelz1980 New Member
    Claremont, Florida
    first time i here about this.. don't trust everything people say, as well as advisors from crutchfield, just make sure your system doesn't exceed 30amps don't wanna fry or damage sensitive electronics
  5. ErikaM
    San Francisco
    "The MultiFunction Display units from a 2015 or 2016 Prius V (Faceplate ID 510057) are a substantial upgrade from the 2012 to 2014 MFDs (Faceplate ID 57011), and are not that difficult of an upgrade. The upgraded unit can be found on eBay for ~$225. "
    Hi Gromitto!
    I just saw your responses! thank you!
    i was told that there are no units that will work with the backup camera navigation. Do you know if these are integrated
    (The MultiFunction Display units from a 2015 or 2016 Prius V (Faceplate ID 510057)
  6. Weirderal
    Weirderal Junior Member
    45
    Pennsylvania, United States
    I'm a bit late to the party here, but what I'm planning to do at some point is grab something like this:
    https://www.crutchfield.com/p_500ILXF509/Alpine-Halo9-iLX-F509.html
    An unfortunate complication (for my interests, anyway) is that I'm really interested in keeping access to the factory settings (headlight delay, locking on shift to park, etc.) in case I would ever sell. Crutchfield (site only; have not talked to an agent yet) says that requires an iDataLink port in the head unit, which also requires some extra "iDataLink Maestro" module in the installation kit (so the full install kit comes to around $250 alone). And the cheapest in-stock head unit I'd found was around $500 to begin with.
    It only had a 7" screen, though. If I'm spending the money and taking the time to upgrade, I damn well want a bit more screen space improvement than just 6.5" --> 7.0". Hence, expensive floating screen. 9" seems to be about the sweet size where it wouldn't overlap with the vents or climate controls, but still be a significant upgrade.
    But with how the interior of the v just seems perfectly designed to not have any "ideal" place to put a phone, this feels like the only way I might ever be satisfied. Meantime the best I'm managing is just a cupholder gooseneck type holder in the center console.
    It says that the settings options also require it to have a connection to the parking brake somehow, but other than that, I've replaced head units before and I imagine I could manage most of it. And hooking up the steering wheel controls to it would at least satisfy my craving for physical volume controls.
    Just gonna be a while before I can commit to spending ~15% of the vehicle's value on this kind of upgrade.
  7. Duprimus
    Duprimus Junior Member
    Pleasant Hill, CA
    2022 Prius Prime
    I kept the outdated JBL unit with the Navigation and resorted to the available aftermarket add-ons. It saved me a lot of rewiring hassles and additional interfaces to retain most of the factory controls. The add-ons have suction cup mounts. The output sound is directed to the auxillary input or via FM frequency of your stock head unit. (The unit below is an ATOTO P8 with wireless Apple Carplay/Android Auto)
    doctorman, HeliosMagnus and icyrius like this.
  8. HeliosMagnus
    HeliosMagnus New Member
    Spokane Valley, WA
    2014 Prius v wagon
    Wow thanks for this I had no idea this was an option!
  9. Sand Hurst
    Sand Hurst Junior Member
    Toronto
  10. doctorman
    doctorman Member
    209
    35
    NY 11020
    What is new in the 2015 version 510057
    Any news on 2017 model yet?
  11. icyrius
    icyrius Active Member
    238
    114
    Florida, USA
    2014 Prius v wagon
    I have also been wanting to upgrade mine and found these choices on EBay
  12. GotVolts?
    GotVolts? Junior Member
    Casselberry, FL
    2014 Prius v wagon
    I saw a couple of those too and was curious but I need to look at the stats of what power they output and how much they readily hook up to the system as a whole. I can deal with losing the car information, but I'd like to keep the steering wheel control and add nav and hopefully old school iPod controls. Newer alpine head units have most of that, minus the iPod part...
  13. pwpaul
    pwpaul New Member
    toronto
    I would like to replace my 57015 (the Canadian version of 57011) with the identical 57015 unit. Anyone know where I can get a working used one?
