Prius v antenna base
Discussion in 'Prius v Audio and Electronics' started by unterhausen, Feb 18, 2018.
  1. unterhausen
    unterhausen Junior Member
    64
    State College, PA
    Some time ago, my wife managed to break the antenna base on her Prius v, but I put the antenna back on and it worked well enough that she tolerated it. I cleaned some snow off of her car and managed to dislodge the antenna, and it fell off while she was driving. So now I'm thinking it's a good time to replace the antenna base. Watching youtube videos, it doesn't seem so hard.
    I'm not sure what trim level the car is. It doesn't have navigation. There appear to be two parts that would probably work on the car, but I'm not sure which to buy. Is there a way to tell from the VIN?
  2. rjparker
    rjparker Tu Humilde Sirviente
    10,493
    6,582
    Texas Hill Country
    Take the vin to a dealer parts house and they can tell you the actual part number. There are three different per car depending if it has satellite, the cellular emergency feature or just a cd fm. If its a v wagon, I have a pdf on here on how to access it. You do have to remove several panels. Plus the pdf shows where I bought it for much less than the local dealer.
    Sam Bella likes this.
  3. Sam Bella
    Sam Bella New Member
    Montreal Canada
  4. Sam Bella
    Montreal Canada
    Hi Parker,
    This is Sam from Montreal Canada. I just joined the forum. My daughter just broke the base antenna with the garage door :(
    I found interresting your message in this forum. I could find the PDF. Could you please send it to me and also the link where to buy the base antenna.
    I have have Prius V 2012.
    Thanks in advance
    Sam
  5. rjparker
    10,493
    6,582
    Texas Hill Country
  6. Sam Bella
    Montreal Canada
    Thanks Parker, I will check that.
    Have a good day
    Air_Boss likes this.
