Prius V battery coolant?
Discussion in 'Prius v Technical Discussion' started by Paul11M111, Nov 24, 2020.
Tags:
  1. Paul11M111
    Paul11M111 New Member
    Memphis, TN
    so I was pulling the jack out of my Prius and found in the spare tire well a bunch of liquid. It’s viscous and a medium brown, about like heavier weight motor oil would look. No smell to it.
    Does the battery use any kind of liquid coolant? It’s the only think I could think of since there is no sunroof and the door and window seals look tight with no discoloration or signs of leaks. No warning lights are on and performance seems the same as it always has. The only think that seems off is that I do hear a gurgle when I shut the car off.
    It’s 165k miles. I’d take a photo but it doesn’t show all that much in there.
  2. lrisius
    lrisius Member
    120
    56
    Illinois
    2015 Prius v wagon
    There's no coolant for the battery. No idea what it is- my guess is some kind of spill that collected in the tire well. Could there have been a spill you aren't aware of? Are you the original owner? Other drivers? How long since you have looked in the tire well? These are some of the things I would be pondering.
    Good luck!
    Paul11M111 likes this.
  3. Leadfoot J. McCoalroller
    7,237
    6,784
    Pennsylvania
    2018 Prius c
    Battery is air-cooled; you found something else. Your description doesn't match any substance naturally included in that part of the car.
  4. Paul11M111
    Memphis, TN
    Awesome! That makes sense.
    I have had the car since February and I hadn’t ever looked in the spare area before. Yeah, I guess someone emptied a quart of oil before I got it and the dealer didn’t look/care. So weird!
    Thanks for the reply!
    lrisius likes this.
  5. Tim Jones
    Tim Jones Senior Member
    1,708
    553
    SE Texas
    2011 Nissan LEAF
    what was it??????
  6. Paul11M111
    Memphis, TN
    Honestly, I don’t know! My very best guess is that it’s unused motor oil. I’ll be sopping it up later today.
  7. Air_Boss
    Air_Boss Senior Member
    3,988
    1,090
    New Yawk
    Congealed rodent urine?
  8. Paul11M111
    Memphis, TN
    Lack of droppings suggested otherwise. Unless it was one really big one.. and that’s just frightening.
    bisco and Air_Boss like this.
  9. TMR-JWAP
    TMR-JWAP Senior Member
    6,329
    6,005
    Columbia, SC
    This was a totally unexpected path....gross
    Never saw that coming...
  10. Air_Boss
    3,988
    1,090
    New Yawk
    They frequently dine on Toyota’s soy based wiring sheathing and insulation.
  11. vvillovv
    vvillovv Senior Member
    3,747
    1,320
    NY
    @Paul11M111 It might just be a coincident that the oil wasn't cleaned up. But with a used at 165k - since I've had trunk leaks that were near impossible to find, even by the pro's, I recommend to keep your eye on it especially after heavy driving rain and/ or after heavy snow melt. I even have waxed paper liner in one of my spare tire wells and have the repainted spare also wrapped in waxed paper, so if it gets wet even once, I'll notice next time I look.
  12. rjparker
    rjparker Tu Humilde Sirviente
    8,102
    4,805
    Texas Hill Country
    I use 78% nitrogen to cool my battery.
    Raytheeagle, vvillovv and Air_Boss like this.
  13. Tim Jones
    1,708
    553
    SE Texas
    2011 Nissan LEAF
    I don't have the big cover on my Traction Battery.......................
  14. ChapmanF
    15,859
    I mix mine with some oxygen and CO₂. I've heard some people add pet hair.
    Goodapollo and Air_Boss like this.
  15. vvillovv
    3,747
    1,320
    NY
    Reminds me of CPU overclockers back around the turn of the century hitting an amazing 4Ghz on the old single cores. How cool are your batteries?
  16. ChapmanF
    15,859
    Depends on the temperature and pressure of the nitrogen. I run mine at about 1 atm (absolute). Sometimes less if I'm traveling in the mountains.
  17. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,482
    Bay Area, California
    2019 Prius Prime
    Just keep the dihydrogen monoxide content low;).
    I hear electronics like lower numbers there(y).
    Air_Boss likes this.
  18. vvillovv
    3,747
    1,320
    NY
    Doesn't most everything
  19. Air_Boss
    3,988
    1,090
    New Yawk
    With CAI and a Boost kit...
    vvillovv likes this.
  20. Air_Boss
    3,988
    1,090
    New Yawk
    Standard Day...
    Raytheeagle likes this.
