Prius V Battery same as Gen 3 Battery ?
Discussion in 'Gen 3 Prius Main Forum' started by CK9887, Aug 5, 2019.
  1. CK9887
    CK9887 Junior Member
    The Woodlands. TX
    I have a 2010 Prius.....
    Was wondering if the Prius V which came out in 2012 uses the same hybrid/traction battery? I read a few articles stating they were the same, but the part numbers seem to be different?
    Does anyone know if they are identical or is there a difference between the two?
    Thanks
  2. ALS
    ALS Active Member
    590
    294
    Pittsburgh
    I did a quick check and it looks like the 2010 is a different part number from the 2012. The 2012 part number covers all Prius from 2011 through 2017.
    It might be the same dimensions and just bolt in and it might not.
    I know one of our battery experts will check in sooner or later for the best answer.
    Battery for a 2010 regular Prius hatchback
    2010-2011 Toyota Prius Battery Assembly G9510-47062 | Toyota of Des Moines Parts
    Battery for the 2012 Prius and the V
    2011-2017 Toyota Battery Assembly G9510-76012 | Toyota of Des Moines Parts
    #2 ALS, Aug 5, 2019
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,213
    5,902
    Columbia, SC
    Yes, they are different, but the differences are not significant.
    The 47062 has slightly different fasteners that affix the main case cover to the case floor. The 47062 uses studs/nuts and 2 bolts while the 76012 uses all studs/nuts.
    The 47062 has the rubber vent tubes and the plastic flow blocker is shaped to allow the vent tubes to pass through. The 76012 does not use the vent tubes and the flow blocker is shaped appropriately.
    One of the three plugs where the car harness connects is oriented slightly different due to having a slightly different mounting point on the case. Everything still plugs in fine and all trunk components fit with no interference.
    All the mounting points are identical. All the ductwork is identical. Everything that really matters is identical. Just transfer the rubber vent system tubes and flow blocker to the 76012 model. Or don't, considering they stopped using them a year or two later anyway..
    There are no differences that can't be worked through. How do I know this? Because I just installed a G9510-76012 HV Battery into a 2010 Prius today..........and it rocks...
    Those were the only differences I was able to notice when I had them side by side and with the covers removed.
    #3 TMR-JWAP, Aug 5, 2019
    Coots, SB6, strawbrad and 7 others like this.
