Prius V Bus Bar Replacement?
Discussion in 'Prius v Main Forum' started by Andrew Soleman 7022, May 15, 2024.
  1. Andrew Soleman 7022
    Andrew Soleman 7022 New Member
    Hey,
    I recently upgraded my hybrid battery to the Nexcell Lithium battery. I learned that my Bus bars are corroded and though they can be cleaned, may be compromised deeper into the wiring.
    I went to the Toyota dealership, and they were unable to get parts to replace these.
    Does anyone have experience with this and or advice on replacing these bars or a source to do so. There are a few used options on Ebay, but the Toyota mechanic said that used is not a good option as the wires could also be compromised within. Hoping to find new ones, if possible, otherwise I will just have to thoroughly clean the current ones and hope for the best
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,191
    5,885
    Columbia, SC
    Google ACENBAY
    I think member @VZvrtny
  3. AzusaPrius
    AzusaPrius Senior Member
    1,819
    809
    When you go to AcenBay.com use promo code "azusa" to save 10%
    Also they have a Nexcell kit that has the right amount of bus bars versus a complete standard kit.
  4. Andrew Soleman 7022
    Thanks, this is great!!!!!
