Prius V camera housing rattle
Discussion in 'Gen 3 Prius Accessories and Modifications' started by creativeguy, Feb 17, 2011.
  1. creativeguy
    creativeguy Member
    301
    17
    CA
    The plastic housing covering the LKA camera at the top of the windshield is rattling a lot. If I apply some pressure to it, the rattle stops. The housing doesn't fit tightly against the windshield, so I can't lubricate the joint or use a thin shim to immobilize it. I did notice that if I shoved my finger in the gap between the housing and glass that the rattle stopped, so pulling the housing down a bit would work. I'm thinking I can find a thick clear rubber stick-on foot and apply it to the glass, wedging it between the glass and plastic. Anybody have any other good ideas?
  2. 32kcolors
    32kcolors Senior Member
    5,683
    952
    124
    Redondo Beach, CA
    Why ask if we have good ideas? Take it to the dealer to get it fixed under warranty.
  3. Thai
    Thai Prius Neophyte
    1,197
    89
    x2...should be a simple fix...why waste your time and money....
  4. mlgreve
    mlgreve New Member
    17
    Greer
    Had the same problem. I took the housing down, applied some double sided tape.
    Problem solved.
