Prius V excessive road noise
Discussion in 'Prius v Main Forum' started by Vladimir Urdov, Apr 24, 2021.
  1. Vladimir Urdov
    Vladimir Urdov New Member
    Chicago
    2015 Prius v wagon
    Does anybody else experienced an excessive road noise on a Prius V ? I have a fairly new Pirelli P4 tires on it so it’s not from the tires...
    52,395
    how long have you owned it? when did the noise increase?
    new tires can be noisy
  3. Vladimir Urdov
    Chicago
    2015 Prius v wagon
    I own it about an year , I noticed that my right windshield pillar cover has gap between the ceiling , the tires have about 1000 miles on them .
    52,395
    i guess excessive is subjective. i find all prius to be very noisy
  5. Vladimir Urdov
    Chicago
    2015 Prius v wagon
    May be you are right , I’m considering it to my 09 Camry and the Camry is much more quiet , but I didn’t drive the Prius from a while and may be it was always like that .
  6. Kenny94945
    Kenny94945 Active Member
    858
    433
    Sausalito
    2016 Prius v wagon
    That's the important question...when did you notice the change in the noise?
    Changing to a different brands of tires can be the main cause of an increased or new road noise complaint, even though you are ruling this out.
    Wind noise, engine noise, road pebbles hitting the undercarriage, rattles, a hum - what is the noise?
    Aaron Vitolins likes this.
  7. bisco
    52,395
    agreed, our hycam is so much quieter, smoother and more comfortable.
    putting michelin energy savers helped with tire noise on my 2012, but the car is still a rattletrap, and there is little to no soundproofing
  8. Vladimir Urdov
    Chicago
    2015 Prius v wagon
    I think that the noise increased after they replaced the dash cover and it’s like a wind/road noise . I’m wondering if there was some sound absorbing matts on the dash which they didn’t put on the new dash...
    #8 Vladimir Urdov, Apr 25, 2021
  9. Kenny94945
    858
    433
    Sausalito
    2016 Prius v wagon
    Ok there's a lead....dash panel removed and replaced.
    That is a big job, there are some posts showing the procedure.
    Maybe another question to ask is if the windshield was ever replaced?
    If dash related wind noise, I would start by look at the dash ends/ sides near the door..
    Inspect that all the seals, trim, clips/ bolts in place and secure
    Then the rest may not be so easy to inspect.
    For example, the cabin filter and its intake track.
    For example the center console components/ area and its sealing to the floor/ chassis.
    Maybe a trick, in a darkened garage, place some lights in the cabin, life the hood and look for a light leak/ source.
    And vise a versa, place lights in engine compartment and look for light leak in the cabin.
    Maybe a rubber plug is missing and there is a visible gap, maybe not.
    I don't think there is any sound deadening on the dash pad.
    Still, tires are a major source of road noise increase, I describe as a hum.
    Mirror turbulence and air leaks from the windshield or doors are a major source of wind nice.
    That's my two cents.
    Good hunting.
  10. Cinco
    Cinco New Member
    17
    Tennessee
    I had the same issue and changed out all 4 tires to Michelin Pilot Sport which helped but not completely. After some research and listening, I changed the rear wheel bearing on the passenger side. Since then the car is whisper quiet. I am happy to share how I did it myself with a 115.00 part and 3 hours of work. It is easy to do if you have done any brake work in the past. If you live near Nashville TN I am happy to assist in person.
    I almost forgot Before the bearing change I soundproofed the rear with deadening material. Easy to do.
  11. Vladimir Urdov
    Chicago
    2015 Prius v wagon
    It was from the windshield pillar on the right side which had a gap , the top clip was put in the incorrect way and once I turned it around the gap disappeared and the car became much more quiet .
    JohnPrius3005 and Aaron Vitolins like this.
  12. bisco
    52,395
    congrats, well done!(y)
  13. Vladimir Urdov
    Chicago
    2015 Prius v wagon
    Thanks !
  14. cmiles97
    cmiles97 New Member
    17
    Tampa, FL
    In general the V is a very loud highway speed car. Sudden changes indicate something new but I see you found it.
