Prius v Fender removal
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Jeffrossi, Jan 4, 2020.
  1. Jeffrossi
    Jeffrossi New Member
    Vancouver
    2013 Prius v wagon
    I'm contemplating replacing myself a damaged Fender from my Prius v 2013.
    (Not my actual car)
    The biggest question that remains is how would I remove the window near the side mirror to reach those 2 connecting points?
    Did anybody has had a similar experience? I should be giving it a try myself anyway.
  2. Elektroingenieur
    2,515
    3,258
    Three Touring
    In the Repair Manual (more info), see the topics under:
    • Vehicle Exterior: Window/Glass: Front Side Fix Window Glass
    • Vehicle Exterior: Exterior Panels/Trim: Front Bumper
    • Vehicle Exterior: Exterior Panels/Trim: Rocker Panel Moulding
    Several of these topics have links to other sections of the manual. The window assembly is shown as a non-reusable part, by the way.
    In the Collision Repair Manual, see Vehicle Exterior: Body Weld Point: Specified Torque: Components, which gives the torque specification (5.0 N·m) for the eight bolts that hold the fender in place.
    Parts catalog references:
    Jeffrossi likes this.
  3. Newsie11
    Newsie11 Junior Member
    CNY
    2014 Prius v wagon
    Those two points you are referring to are not bolted. They are more like locator studs.
    Once you get all the bolts out, slide fender forward till it pops off those two points.
    m-ikea and Jeffrossi like this.
  4. Jeffrossi
    Vancouver
    2013 Prius v wagon
    Thank you, a lot
