Prius v Five (Fog lights)
Discussion in 'Prius v Accessories and Modifications' started by Engz, May 25, 2017.
  1. Engz
    Engz Junior Member
    New York
    2013 Prius v wagon
    Does anyone know how to wire the fog light to be stand alone?
    Meaning having the fogs on while head lights are off or only have the DRLs on?
  2. Air_Boss
    Air_Boss Senior Member
    3,952
    1,083
    New Yawk
    To illuminate the fogs as DRLs, use a >+13.2V sense module as trigger for a standard fog light relay harness powered from the +12V battery post in the under-hood fuse panel.
  3. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    Or, wire a standard relay to a fuse tap on a circuit that is only powered when in Ready mode. One such relay is the inverter pump fuse. No need for a voltage sensing module.
