Prius V losing antifreeze at higher speed only
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Billbob, Feb 7, 2023.
  1. Billbob
    Billbob New Member
    Arkansas
    2012 Prius V loses antifreeze at 75 mph but not at 65. Thermostat?
  2. rjparker
    rjparker Tu Humilde Sirviente
    11,063
    6,933
    Texas Hill Country
    Head gasket if there is not an obvious leak on the ground
  3. Mendel Leisk
    42,314
    What’s the miles?
  4. Kenny94945
    Kenny94945 Active Member
    864
    439
    Sausalito
    2016 Prius v wagon
    Thermo itself...no.
    Leak... yes.
    I understand you are indicating that engine heat (higher rpms) expands "something" causing a loss of fluid.
    Yes, knowing the mileage could be helpful.
    Yes, as RJ mentioned, no coolant on the ground or elsewhere in the engine bay, could very well lead to a head gasket.
    FWIW First thing I would do? I'd pressure test the coolant system.
    (PS One item sometimes overlooked is the radiator cap itself leaking and evaporation being a loss of coolant cause.)
    Good luck.
  5. Mendel Leisk
    42,314
    There might not be a radiator cap, assuming it’s like 3rd gen hatchback.
