Prius v (lowercase v for the Prius v wagon) Transaxle Drain and Refill PLUGS
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Johnny M, Mar 3, 2015.
  1. Johnny M
    Johnny M New Member
    2013 Prius v wagon
    Is the washer on these two plugs the same as the oil drain plug? Does anyone know the OEM part number?
  2. exstudent
    exstudent Senior Member
    2,213
    901
    Torrance, CA
    Most likely NO. Previous generations, transaxle fill and drain plug used the same crush washer. Engine oil drain plug was a different crush or felt washer.
    Engine oil drain plug washer part# 9043012028.
    Call your local dealer to confirm and get the part # for the transaxle crush washer.
  3. Mendel Leisk
    38,738
    If you're at dealership getting Toyota ATF-WS just ask for the drain plug washers?
