Prius v (lowercase v for the Prius v wagon)... Vacuum Switching Valve Fault Killed Engine...
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by David Warshaw, May 10, 2016.
  1. David Warshaw
    David Warshaw Junior Member
    My 2012 Prius v (lowercase v for the Prius v wagon) (~80,000) bucked/almost stalled at the hybrid/gas motor handoff when starting to roll (very low speed). Check Engine light came on. I drove home (60 miles, highway) using the POWER MODE without problem. Next morning, on my way to take car to service, several warning lights came on. I began to travel, and apparently the car was in EV mode only, which drained the batter. Car crapped out on a highway entry ramp. It started up after several tries and I was able to get to the dealership.
    Was told diagnosis would cost $127.00. BUT... when service tech called, I was told problem was VACUUM SWITCHING VALVE shorted out the system. AND... THANKFULLY... there was a service bulletin on this issue so the replacement/repair was done under warranty at no cost. Had to send out for part, but was provided a loaner vehicle, so was not inconvenienced. Got car back next day.
    Tech said although this is a known fault, it is not frequent enough for a recall; although there is quite a bit of risk should this happen when the car is on the highway, or -- as in my case -- on a blind-curve entrance ramp.
  2. Chazz8
    Chazz8 Gadget Lover
    744
    234
    61
    Central New York
    Were there any error codes on your service write-up that you can share with PriusChat that members can use to diagnose this problem?
    49,371
    thanks for the heads up. tsb's vs recall's are strange bedmates. unfortunately, in the big picture, car makers are not concerned about the possibility of a few accidents/injuries/deaths, compared to the cost of a recall.
