Prius v (lowercase v) transmission issue
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by ef817, Aug 7, 2014.
  1. ef817
    ef817 Junior Member
    2013 Prius v wagon
    2013 Prius v Two with 17,000 miles. Put the car in park so I could pay for parking as I was exiting a garage. The car would not go back into drive until after I turned it off and restarted it. This happened once before as I was getting on a ferry. Has anybody else had this happen?(sorry, I put the v in caps.)
    #1 ef817, Aug 7, 2014
  2. CLUBGUY
    CLUBGUY Member
    293
    49
    Cincinnati
    Somewhat similar experience when first powering up; when I attempt to activate "drive" mode it beeps and the "parking" light flashes......Have to power down and start the power up sequence over....
    Figured I must be doing something wrong; just do not know exactly what..???
  3. ef817
    ef817 Junior Member
    2013 Prius v wagon
    That's exactly what it does. Figured I would post on here before I went to the dealer.
  4. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    Almost sounds like you were trying to put it into B mode.
  5. ef817
    ef817 Junior Member
    2013 Prius v wagon
    Nope. I was shifting into Drive from park. I had to turn off the car and restart it to get it to go into D.
  6. orenji
    orenji Senior Member
    5,886
    3,487
    Was your foot on the brake?
  7. bisco
    51,155
    are you shifting too quickly after powering up?
    #7 bisco, Aug 7, 2014
  8. ef817
    ef817 Junior Member
    2013 Prius v wagon
    No. The car was turned on. I was in park attempting to shift into Drive.
    Pretty sure it was.
    #8 ef817, Aug 8, 2014
  9. bisco
    51,155
    i realize you were in park attempting to shift into drive, but if you attempt it right after powering up, it don't work unless you wit a few seconds.
  10. Priuswagon
    Priuswagon I love my Prius
    112
    Kingston Washington
    Yes if I start the car fast it happens. I figure the electronics get confused or something.
  11. bisco
    51,155
    right, it has to go to 'ready' before shifting or your brake switch may need adjustment and more pressure is needed than spec on the pedal.
  12. jzchen
    jzchen Newbie!
    3,316
    1,020
    Arcadia, CA
    I agree it has to show "READY" before you can shift out of P, but in ours that is almost instantaneous. Maybe accidently didn't push on the brake is my first suspicion as well, or maybe not press on the brake hard enough to disengage the shift lock.
    Next time it happens note if the READY light is on. It may have also been you pushed the POWER button instead of P. (I know some people go straight to that instead of pushing P first so maybe you've accidentally done that.)
    Otherwise it's probably dealer time for the car....
    SCH-R530M ?
    #12 jzchen, Aug 8, 2014
  13. kithmo
    kithmo Couch Potato
    2,404
    2,774
    47
    South Yorkshire, UK
    did you open the door to pay for parking ?
  14. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    The car sounds like it is operating normally, and complaining about *something* that prevents it from following hte driver request to enter D.
    Open door and inadequate brake pressure are good guesses.
    I've come to really appreciate the Prius looking over my shoulder. Amazing the dumb things I have done over the years.
