Prius v oem wiper refills wrong size
Discussion in 'Prius v Main Forum' started by Quaternaria, Feb 6, 2022.
Tags:
  1. Quaternaria
    Quaternaria Junior Member
    SF Bay Area
    Hi--
    I have a 2012 Prius v. I have the original wiper blades, but when I ordered refills they were too thick. They were the same length. Anyone else have this problem?
    On the (original) driver blade (metal) is the code 202326a
    The rubber refill is part 85214-47051
    Thanks so much!
  2. rjparker
    rjparker Tu Humilde Sirviente
    7,977
    4,717
    Texas Hill Country
    Quaternaria and Air_Boss like this.
  3. Air_Boss
    Air_Boss Senior Member
    3,952
    1,083
    New Yawk
    It’s not rocket science.
  4. gromittoo
    gromittoo Active Member
    718
    286
    philadelphia
    2013 Prius v wagon
    I buy RainX beam style 28 inch at Walmart for the driver's side (B-28-1, Jhook style) for roughly $14 each. That is 2 inches longer than the 26 inch OEM. I like the larger clearing area, and have had no issues. I like Beam style since there is zero chance that the "refill" will come off, and scratch the windshield. My Chrysler van has nasty scratches from a refill falling off.
    #4 gromittoo, Feb 9, 2022
    Quaternaria likes this.
  5. Quaternaria
    SF Bay Area
    Thanks for the replies, I removed the original blades and put on Bosch Icons, when the pandemic dies down I will take the original blades--clearly marked Toyota--to the dealer parts window.
    Maybe the dealer put Sienna blades on the who knows, but the oem refills are too wide.
    I wasn't sure whether to get A or B for the passenger side but the B works fine.
    @gromittoo -- that's really interesting about the 28" I may have to try that--did you keep the other wiper at 19?
  6. Air_Boss
    3,952
    1,083
    New Yawk
    I use 28 and 21 front, 11 at the rear.
  7. Quaternaria
    SF Bay Area
    I already bought the replacement but I will try the larger ones next time!
  8. gromittoo
    718
    286
    philadelphia
    2013 Prius v wagon
    I left the right wiper at 19 inches, but I use the same RainX beam J-hook style blade B-19-1 (B-19-2 is not J Hook Style, and won't fit). I actually started using the 28 inch because I "borrowed" a blade from my Minivan, when I needed a quick replacement. I am tall, and I liked having 1 extra inch of the windshield cleared at the top.
  9. Quaternaria
    SF Bay Area
    Amazon sent the wrong blade so I returned it and got the Bosh Icon 28A, leaving the right one at 19, as you suggested.
    So far, works great, thanks. Super quiet.
  10. Abushnell
    Abushnell Junior Member
    2015 Prius v wagon
    A bit late to the party, but I know the answer to your problem regarding the wiper blade refills.
    1. According to the diagrams, the OEM wiper blade is Toyota part number 8521247060 for the passenger side, and 8522247040 for the driver side.
    2. Some Prius V's, including yours and mine, come with Sightline wiper blades. I don't know why.
    3. The sightlines blades use narrower rubber inserts than the OEM parts, and these rubber inserts are not sold separately. If you have Sightlines, you have to replace the entire blade. Sightlines are $23, the OEM blades are $30.
    4. While Air_Boss is technically correct (the best kind of correct) that this is not rocket science, it's certainly not a simple "just buy the refills on the parts diagram" situation. It dismays me to see such a condescending reply from a PriusChat senior member.
    I ended up going to a local pick-a-part junkyard and pillaging some OEM blades from a couple wrecks there. $3 entry, $2 per blade, and the rubber refills were still in good condition. When they wear out in a couple years I can now buy the refills that fit them from my local Toyota dealer.
    geripsy and Quaternaria like this.
  11. Air_Boss
    3,952
    1,083
    New Yawk
    With respect, rubber refills last only six months in UV exposure, and anything sitting in a yard is DOA.
    If in doubt, look at the fitment (J-hooks), measure the sweep outlined on the windshield, see how much un-swept glass is available inside the pillar at outer edges and at the inner edges, and measure that distance.
    What you will find is that the windshield (and motors) can easily handle a larger replacement blade sweep -- a full inch in length on both sides -- which we have done since we first replaced the OEM blades.
    Brackletless or frameless "aero" blades are far superior to OEM refills.
  12. Quaternaria
    SF Bay Area
    Interesting--I gave up on the refills and got the Bosch blades, but no reason to hang on to the original blades if there are no refills. They do have the Toyota logo on them but as long as the Bosh blades work I guess that's the easiest fix, if if not the best for the environment......
  13. Quaternaria
    SF Bay Area
    Yup, added an inch to the driver side with the Bosh no problem and they don't squeak. Of course, as soon as I say that....
