Prius V sputtering
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Abdul268, Mar 25, 2024.
  1. Abdul268
    Abdul268 Junior Member
    Bristol CT
    Two Eco
    My 2017 V Prius has started stuttering, jerking only when Iam in eco and rpms are low. Once I give full gas, engine runs like normal with no hesitation. Car has 200K. It’s not a headgasket issue because I already tested for that through my coolant and headgasket is ok. I have included a video of live fuel trim data when the engine is hesitating and I floor it at the end of the video so I get reading when engine is running ok. I do get a cylinder 2 misfire code. But I want to double check if my fuel trims are normal or not. I have already ordered plugs and coil for it but want to check my fuel trims. If Anyone with experience can tell me if my trims look normal or within range? Thanks!
    49,371
    have you cleaned the egr circuit?
    Tim Jones and Mendel Leisk like this.
  3. Mendel Leisk
    38,644
    How'd you test?
    Tim Jones likes this.
  4. Tim Jones
    Tim Jones Senior Member
    1,706
    553
    SE Texas
    2011 Nissan LEAF
    Are u sure you haven't lost Any Coolant?
  5. ChapmanF
    15,433
    ^^^^ In particular, the small passages in the intake manifold?
  6. bisco
    49,371
    18 days...
