Prius v Sun Visor Won’t Stay Put
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by prevee5, Apr 10, 2024.
  1. prevee5
    prevee5 Member
    114
    Monrovia, California
    When I push my driver’s side sun visor all the way forward against the windshield, it will not stay in place. Is there any fix for this? Replacement visor is very pricy.
  2. Air_Boss
    Air_Boss Senior Member
    3,939
    1,076
    New Yawk
    Is the clip on the right hand end in place and securing the sweep rod? Or do you mean the visor rotates freely on the rod?
  3. ivanhoe
    ivanhoe Member
    66
    26
    2015 Prius v wagon
    There should be a philip head screw at the pivot area, just tighten it up a bit!
  4. prevee5
    prevee5 Member
    114
    Unfortunately for my model there is no visible Phillips head screw. The only screws are those that attach the visor to the ceiling.
    I think there’s something broken inside because as you push the visor up against the headliner, there’s a loud popping sound when the visor is about 2 inches from the ceiling. Was hoping for a fix since replacement is so expensive.
  5. prevee5
    prevee5 Member
    114
    Visor attachment points are secure. Just won’t stay against windshield position and drops down about 2” from ceiling position.
  6. ivanhoe
    ivanhoe Member
    66
    26
    2015 Prius v wagon
    Your local auto wrecking yard might be your source for a deep discount option.
  7. Air_Boss
    3,939
    1,076
    New Yawk
  8. prevee5
    prevee5 Member
    114
    Yes. All hardware is present and attached normally.
    Visor won’t stay in full forward position against windshield and won’t stay up against ceiling. In both cases, visor flops down freely about 2 inches or so. Makes it difficult to secure a fold up sunshade against the windshield.
  9. Kenny94945
    Kenny94945 Active Member
    780
    397
    Sausalito
    2016 Prius v wagon
    From the written descriptions.... to me:
    a) it seems the sweep rod has broken/ snapped at a point as it travels through the sun visor
    b) the rod broke or unlodged inside the pivot mounting mechanism.
    Perhaps both theories were caused by someone using the sunvisor for leverage ie they pull down on it.
    so....
    Remove the pivot mount and inspect for possible DIY repair.
    Buy a new assembly if the rod is broken inside the visor, as it may be impossible to professionally DIY fix.
    Good luck.
    Air_Boss likes this.
  10. prevee5
    prevee5 Member
    114
    Thanks all for the possible theories. I’m not sure what’s inside a sun visor so this is great information. Will tinker around with it to see if I can figure it out and report back.
