Prius V Torklift Ecohitch install review
Discussion in 'Prius v Main Forum' started by Craig C, Oct 22, 2018.
  1. Craig C
    Craig C New Member
    Bellingham, WA
    Hey fellow V owners, I searched here for a couple months for the Prius V Ecohitch by Torklift without any luck so last week I decided to call and just order new. The receiver arrived Friday and I installed it that day and wanted to give my thoughts on the install for which I did myself.
    Overall the process was really easy from ordering to having it on my doorstep within 4 days (I do live 90 miles from Torklift so that probably helped!).
    Items needed for install.
    1) Socket set (metric and standard) with a wobley for getting around hard corners near muffler hanger.
    2) Gloves so you don't bust your knuckles.
    3) grease for bolt threads in case you ever want to get the receiver off.
    4) Ability to easily access bottom of car (curb, loading dock, jacks)
    5) Coffee/beer depending on time of day (I went coffee as it was early AM).
    6) Torkwrench
    The setup:
    The receiver came nicely boxed with all the proper protection inside. I actually did preread the instructions which really helped. First step was to back the car to the edge of our parking spot off the alley, a bit sketchy. This allowed good access underneath which I believe is essential. If you don't have a jack and stands you could easily use some blocks of wood and back it up one of those parking barriers or find some type of loading dock or something. I believe this saved me a lot of time rolling around on my back with a headlamp.
    The process:
    The old bolts came out pretty easily without having to use WD40/PB Blaster. They say to keep the old driver side tie down, but I tossed it figuring I would just find it in my shop in 10 years and not know what it was. Once all the old stuff was removed, I got my neighbor and we moved the new receiver up in place. Pretty straight forward. We held the new hardware in place with a couple of the new bolts on the driver side. The passenger side is the only pain in nice person in the entire process. Using a wobley on the end of my socket, I was able to get one of the new bolts in place and then got the second with my fingers. Everything else was super straight forward. Overall process was 1.5 hours (including feeding two kids breakfast).
    Final thoughts:
    I thought the install was super straight forward. Directions were more than sufficient and prereading over a cup of coffee really helped. I did not opt for wiring in the receiver as we don't plan to do any towing. I really like how tucked up and away the receiver is and it combined with our bike rack makes for a really good setup. Overall 5 out of 5 stars. Yes, its a bit expensive, but well worth the money in my opinion.
  2. Craig C
    Craig C New Member
    Bellingham, WA
    a few pics...
  3. Craig C
    Craig C New Member
    Bellingham, WA
    a few more....
  4. rjparker
    rjparker Tu Humilde Sirviente
    7,918
    4,680
    Texas Hill Country
    Looks like a nice install. Assume it is the 2" version, it looks like mine. It is a little heavy for one guy and your lift solution was far better than working on your back under the car. If I had to do it again I would get it on a lift one way or the other. I kept the original brackets and bolts (new ones are longer) just for the day when you might remove the hitch. If you sell the car, the hitch might be worth some money to someone other that the typical Prius buyer or dealer. I keep my original parts in the hatch cubbies.
    #4 rjparker, Oct 22, 2018
    Craig C likes this.
  5. rjparker
    7,918
    4,680
    Texas Hill Country
    Attached is a pdf scan of the installation instructions. The pics are not great and were not any better in the original photocopied instructions. And they really only make sense when you are able to look under the car. I had suggested at the time that a good isometric assembly drawing would be helpful. The key is removing two existing shipping hold down brackets and using those holes for four of the hitch bolts using longer bolts. Then there are two add on straps using two existing holes on the subframe. Pic from instructions with my notes and arrows.
    #5 rjparker, Oct 22, 2018
    Craig C likes this.
  6. Craig C
    Craig C New Member
    Bellingham, WA
    RJ- Yes on the 2". We didn't want another rack as we already owned a 2" receiver bike rack for our Tundra. Also liked the lower profile (closer to back of car) so I didn't want to use a conversion.
    Living in the PNW, we don't have much rust. I guess I would add if you live in salty (rusty) area you might want to start a couple days early with spraying the old factory bolts prior to doing your install.
