Prius V Touchscreen issues
Discussion in 'Prius v Audio and Electronics' started by Justin Henderson, Oct 16, 2023.
  1. Justin Henderson
    Justin Henderson Junior Member
    39
    Salt Lake City
    2014 Prius v wagon
    All of the sudden the touch screen on my 2014 stopped working. I can navigate the other screens with the side buttons. The little bit that I've been reading makes me believe that the unit is toast. Is there any other type of fix or way to diagnose the issue? Or do I just need to look for a replacement on ebay?
    Thanks!
  2. rjparker
    rjparker Tu Humilde Sirviente
    7,918
    4,685
    Texas Hill Country
    I would power cycle the car first but the mfd units do go bad. Be sure you get the right one plus the extension box if you have maps built in. Most v3’s before 2015 have a 57011 with the bottom extension box.
  3. Justin Henderson
    39
    Salt Lake City
    2014 Prius v wagon
    I had a feeling you’d be the first to respond
    When you say power cycle so you mean just turn the car off and on?
    If so, I tried that several times.
    iPhone ?
  4. rjparker
    7,918
    4,685
    Texas Hill Country
    Disconnect the rear negative battery cable at the chassis below hatch (easy plus a chance to check that connection).
    The attached shows removing the mfd starting on page 4. Don't remove the extension box unless you have to move it to another unit.
    #4 rjparker, Oct 17, 2023
    Air_Boss likes this.
  5. jzchen
    jzchen Newbie!
    3,298
    1,009
    Arcadia, CA
    Is there a reason you’re recommending finding a replacement extension box, vs just plain transferring the current one over?
  6. jzchen
    jzchen Newbie!
    3,298
    1,009
    Arcadia, CA
  7. rjparker
    7,918
    4,685
    Texas Hill Country
    It goes bad as well causing issues.
    jzchen likes this.
  8. Justin Henderson
    39
    Salt Lake City
    2014 Prius v wagon
    My current unit does not have maps. If mine doesn’t use Maps, do I need to worry about the extension box?
    Also, when I got in the car to go to work this morning, the side buttons weren’t working either. I have not had a chance to do a hard reset because I got home from work late last night. But then in the middle of the drive to work this morning the buttons started working again. The touchscreen is still dead. I’m assuming this is all pointing towards failure and I don’t know if I should even waste my time doing a reset.
    iPhone ?
  9. rjparker
    7,918
    4,685
    Texas Hill Country
    If it is a 2014 Prius v Trim 3 it should have a 57011 and you have maps accessed by the App button. Without a functioning extension box you lose maps and some Bluetooth functionality.
    If you are buying used just get what you have so the cables all fit. IMG_3212.jpeg
    Do a power cycle before doing anything.
    #8 rjparker, Oct 18, 2023
    jzchen likes this.
  10. Justin Henderson
    39
    Salt Lake City
    2014 Prius v wagon
    Ok, so I disconnected the negative terminal. Reconnected. No change in the touch screen. Sounds like I need to replace.
    iPhone ?
