Prius v (lowercase v for the Prius v wagon...) Wagon (only) MPG - Please Post Your Results
Discussion in 'Prius v Fuel Economy' started by F8L, Oct 30, 2011.
  1. mikefocke
    3,636
    1,624
    Sanford, NC
    I prefer to report fuelly numbers because they are based on lots of fill-ups and because they are odometer based numbers.
    Any gas pump variations will even out as long as all fills are entered. I notice a variation in pump shut off points affecting the individual tank MPG significantly. When one fill is calculated to be high mileage, the next is going to be low. I assume, since this pattern is so repeated, the pump shut off on the first was quicker than the second. The overall fuelly MPG reported is accurate as individual variations are averaged and become noise.
    I don't try to drive to achieve MPG other than sometimes keeping my speed moderate when I won't interfere with others who drive at higher speeds. I drive in 95 degree F temperature variations, 6F to 101F. A mix of 10 miles, 50 miles and 250 miles per start. 25 to 70 MPH. I don't get as high MPG as some report. But I do get ~EPA. And I do get 100+% better than my previous cars and the cost benefit of getting that improvement on regular gas.
    That is enough for me.
  2. Stevevee
    Stevevee Active Member
    821
    224
    Vermont
  3. SageBrush
    SageBrush Senior Member
    11,627
    2,530
    Southwest Colorado
    Well done!
    I split driving about 50:50 with my wife. She drives faster than me overall, and most of the miles are highway.
    Our last ~ 5200 miles:
  4. Sperez201
    Sperez201 Junior Member
    LB
    2014 Prius v wagon
    I love it. As a previous owner of a C and a Persona,I was worried about the mpg of my v. I got mine on May 20 and I drive 90 miles a day (mostly freeway) - I average 46 mpg . I love it.
  5. Sperez201
    LB
    2014 Prius v wagon
    I purchased my 2015 v on May 20. I drive about 81 miles per day. I have about 1960 miles at this point. The best mpg I have recorded is 56mpg and the least, 37 mpg. I seem to record better times on my commute back to home: 57south/22west/405s in the afternoon than the morning commute of 605n/10east/57south !
  6. Air_Boss
    Air_Boss Senior Member
    3,909
    1,065
    New Yawk
    42mpg summer tires (OEM Toyo Proxes A20 215/45R17), 39mpg winter tires (Dunlop Winter Sport M3 (215/50R17)
    42/40psi summer, 40/38 psi winter
  7. xlnick
    xlnick Junior Member
    Stuart,Fl
    Current Tank of gas, I'm averaging 57.0 mpg for 425 miles - with 2 kayaks on the roof - mostly local driving- I usually don't go over 40 mph. Without the kayaks, I'd be getting over 60-mpg.
    On one tank back in the spring - I actually averaged 77 for 66 miles.
  8. vsavatar
    vsavatar Junior Member
    Livonia, MI
    2015 Prius v wagon
    I'm 800 miles into mine so far, and my last tank got me 48.6 mpg, and that was with about 65% city driving and 35% freeway driving. No matter what, it's doing better than EPA numbers in any case. However, I do live on mostly flat land with very few hills, no mountains, or anything like that. Also, I'm almost sure those numbers are going to tank (pun intended) in the winter due to the vehicle having to warm up prior to it using the electric motor for low speeds.
  9. JAvendan
    JAvendan Junior Member
    27
    Northern San Diego County
    2015 Prius v wagon
    with my commute... up to 80mph with hills and climbs i've been between 40 and 43.
    i'm pretty happy with that!
    joel
  10. RAM v
    RAM v Junior Member
    71
    St. Paul, MN
    2014 Prius v wagon
    7500 miles on my '14 and have gotten just over 50 mpg for last 3 tankfuls (true fill up calculated mpg), and at over 50 mpg half way through present tankful. Mix of city and highway (mostly 55-60 mph on highway runs).
  11. rdgrimes
    rdgrimes Senior Member
    1,740
    444
    New Mexico, USA
    2018 Prius Prime
    Just had my best tank ever at 53.01mpg. 487.4 miles using 9.194 gal. Ave temps in the 80s, city driving.
    ricomtl likes this.
  12. PhillyRick
    PhillyRick Junior Member
    2012 v (lowercase v for the Prius v wagon) 3, 42K mi, Michelin Energy at 38/36 psi. 40.2 mpg overall indicated.
    My wife commutes 25mi each way to work, half city and half (congested) highway; and each summer we drive 800 mi with two canoes on the roof (which brings the mileage down to 32mpg!).
  13. Terry Proveau
    Terry Proveau Junior Member
    Ontario, Canada
    2014 Prius v wagon
    Year of vehicle:
    Date: 2014
    Miles driven: 44000 km
    Gallons Pumped:
    Hand-Calculated MPG:
    Displayed MPG: 44.4 us mpg 53.3 imp mpg since buying this car new
    Average Speed: 60 kph
    Tire Size / Wheel size: 16 inch
    Tire Brand / Model: stock Michelin
    Tire PSI (Front / Back):35/33
    Seasonal Conditions: AC in summer, heater in winter
    Commute Length: 24 km
    Hypermiling Techniques: I drive easy on the petal as much as possible but have driven a couple tanks on power mode with little mileage difference.
    Other: this vehicle has met mileage expectations and was affordable because of the savings monthly in fuel. We drive a lot at over 30000 km/year. Very reliable car with one software recall update completed and regular maintenance, no problems at all so far!
  14. Stevevee
    821
    224
    Vermont
    Interesting couple of months. I've had to make mad dashes on the interstate, 72-75 mph. Headwinds back, cooler weather, rain.
    I've had some miserable mileage lately 35-38.
  15. Bmidd
    Bmidd Junior Member
    Chattanooga
    2015 Prius v wagon
    Just got back from a 1610 mile trip to Texas. I kid you not when I say we had a headwind coming and going from these recent storms over the holidays. 2 adults, 1 child and V was loaded to the gills with the cruise set between 78-85 depending on conditions. We ran all the way from Mississippi border to Chattanooga @ 85 up interstae 20/59 to I-24.
    1610 miles
    43.796 gallons of fuel
    Averaged 36.76 miles overall.
    Not bad overall, we were really killed by the constant 15-20mph winds and the rain we drove in both ways.
    Our 2014 Elantra would do the same trip at the same speeds @ 38mpg but couldn't haul nearly the stuff we carried and we never made the trip in this kind of weather.
    2015 Prius v (lowercase v for the Prius v wagon) Three (Not III)
    Blizzard White(fastest color)
    32% tint all around 50% tint on front windshield
    Tires inflated to 40psi
    Vehicle mileage is now just over 4000
  16. stephane
    stephane Prius v owner
    120
    64
    Quebec Canada
    2013 Prius v wagon
    Those car computer are very offset I just got 50.05 in the last tank my second tank since i own the car. it is winter and im on winter tire
    Real number on fuelly give me 44.3 huge difference at 6mpg
  17. ricomtl
    ricomtl Member
    137
    39
    moon
    2018 Prius Prime
    Technology
    Same here. I've owned the 2015 v since August and I've noted a consistent important gap between what the car MPG reads vs manually calculated on Fuelly.
  18. Eugene Sanchez
    Eugene Sanchez Junior Member
    2015 Prius v wagon
    Driving in Los Angeles, i averaged about 43-45.4 mpg per trip, I'm happy with that with the amount of cargo i get, and still being able to drive over 65mph with a smooth and steady drive.
    Bought in October 2015, now at 2300 miles, 175 miles/week, 25+/day.
    Mix of city driving 40-50mph
    Highway driving of 65-75mph+ (In LA you have to drive much faster to stay with the flow of traffic)
    During the break-in period before 1000 miles, i accelerated much slower and never went over 65mph.
    The computer seems to display mpg at the current moment and at time it seems too optimistic bouncing to 60-99 mpg, which i know isn't accurate.
    And counting each bar on the fuel gauge isn't accurate as well, since each bar does not equal to a fixed number of miles driven. Because often I can sometimes drive 100 miles before the first bar disappears, and I know I don't have another 900 miles to go, if so that would be awesome!
    I trust the most accurate way to measure real mpg, is to manually calculate the miles driven per fill-up trip and divide by number of gallons purchased. I do so like this:
    1. Before filling up look at your odometer example: 1000 miles
    2. Record your previous Range meter as well example: 5 miles
    3. Then hold down the trip button to reset your trip meter to 0.
    4. Next buy 10 gallons of gas, if gas is at $2.80 buy $28.00 and fill up.
    5. Then drive as you normally would and keep driving till your range depletes back down to the previous range of 5 miles.
    6. On your second fill-up record your odometer example: 1455
    7. Then take 1455 miles subtract 1000 miles = 455 miles driven for that trip, your trip meter should reflect this or very close to this number, if it doesn't there maybe a problem with the trip meter.
    8. Your mpg for the trip would be = 455 miles divided by 10 gallons = 45.5 mpg
    Each trip mpg is rarely the same, several factors affect them like weather temperature, number of commutes or a long road trip, and how fast your were driving on average.
    Since the Prius v fuel tank is 11.9 gallons and in the Book Manual states that when the orange low gas light turns on that there is only 1.6 gallons left. Filling up when the orange light goes on and your range is at 5-12 miles is an accurate total if 10 gallons were to be purchased on top of the 1.6 gallons in reserve left would equal 11.6 + gallon capacity, without gasoline overflowing out of the tank.
    I've driven my range down to 0, but quickly filled up. I wouldn't want to risk damaging the fuel tank if i had to drive several more miles past 0, even if 1.6 gallons in reserve is for emergencies in remote areas, allowing perhaps 50 more miles of driving, i've heard of other drivers doing this, if so i'd like to hear more or other calculations you use.
    #438 Eugene Sanchez, Jan 9, 2016
  19. Emcguy
    Emcguy Member
    176
    29
    Australia
    Just completed a 4000km Road trip with 5 people and additional luggage, including tent, weighing maybe 100kg extra. Total for the trip was 5.0l/100km (47MPG). Once again the car performed great even during floods in central NSW where the roads were very dangerous. I feel this standing water ate into my 'score' by around 0.2-0.3 l/100km. Used CC set at 115km/h and around a quarter of the journey was on United's 95RON E10.
  20. Bmidd
    Bmidd Junior Member
    Chattanooga
    2015 Prius v wagon
    What was your hand calculated mileage? The computer is far from accurate.
    iPhone ?
