Prius v Wagon (only) MPG - Please Post Your Results
Discussion in 'Prius v Fuel Economy' started by F8L, Oct 30, 2011.
  1. TripleTransAm
    TripleTransAm New Member
    Montreal, Quebec, Canada
    About 65k miles on my '12 v, got it last November and it's my primary car since my Trans Ams and new '16 Charger RT are stored for the winter. With the exception of a snow storm / ice storm back in early January (38 mpg?) I'm ranging 45-47 mpg tankfuls of mostly highway commuting. When the temperatures finally improve I guess I should expect better? If so, mega impressed.
    Running new Michelin x ice tires with pressures at 37 ish psi if I recall (haven't reset since the temperatures dropped).
  2. Prius from Dad
    Prius from Dad Junior Member
    29
    33
    Toms River, NJ USA
    Just traded in my 2012 Prius V 5 for a 2017 Prius Prime premium. The V had 125,000 and the lifetime mpg was 51.6 but the lifetime calculated mpg was 48.86, a 5.3% difference. Loved that car. Looking forward to driving the Prime. Also ran the tires on the V at 65 psi and they lasted 100k.
  3. Air_Boss
    Air_Boss Senior Member
    1,961
    304
    New Yawk
    OEM Prius V Five 17" Toyo A20 tires at 65psi?
  4. Prius from Dad
    29
    33
    Toms River, NJ USA
    They were (Yokohama?) Blue Earth tires. OEM
  5. Air_Boss
    1,961
    304
    New Yawk
    Never heard of those being OEM. Are they really sidewall-rated for 65psi?
  6. Prius from Dad
    29
    33
    Toms River, NJ USA
    No they were rated as usual 40 something, but after a lot of research, I found that 65 worked for me. I started overinflating with my 99 Solara and found mileage increases and tire life also increases. My Solara tires usually lasted 75k-80k.
  7. Air_Boss
    1,961
    304
    New Yawk
    I'd say you were lucky in several respects.
  8. mikefocke
    1,528
    414
    Sanford, NC
    Somehow at 65PSI I'd wonder at the traction in stopping or foul weather conditions. I notice a difference at much over 40.
  9. Prius from Dad
    29
    33
    Toms River, NJ USA
    I noticed no difference. Not 1 problem in 125k miles.
  10. Gearbreaker
    Gearbreaker New Member
    Vernon, CT USA
    2014 Prius v wagon
    65 PSI? For real? On my Xb I ran the tires at 44 and the belts kept separating. On my V I run 44 to be safe and have had no problems.
  11. bisco
    14,701
    i wouldn't exceed the max wall rating, but ymmv.
  12. Prius from Dad
    29
    33
    Toms River, NJ USA
    Yes, 65 psi for about 90k of that 100k. Not 1 problem except for a screw in the sidewall on one of them at about 70k. I followed a hypermiler forum for a while and some of the guys ran their tires even higher. No one ever had a blowout due to pressure, it's always too low pressure that causes blowouts..
Loading...
