Prius v wagon Top Speed
Discussion in 'Prius v Main Forum' started by JNTcustoms, Apr 17, 2013.
  1. JNTcustoms
    JNTcustoms New Member
    New York
    2013 Prius v wagon
    Just curiosity, what is the top speed of the Prius v wagon? I read a review on MotorTrend.com that Toyota specified a top speed of 103 MPH.
  2. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    I know it has a higher final drive ratio, for better acceleration. That should lower top speed, but I have never personally had mine over 95 MPH, so I am not prepared to say what it is.
    2012 Toyota Prius V First Drive – Review – Car and Driver
  3. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    I have a document with the gear tooth counts for the standard Prius. The top speed of the standard Prius is 113 mph at the MG2 max speed of 13500 RPM, using the standard tires of 195/65R15 tires.
    Substituting the higher final drive ratio of 3.70 for the v, I come up with 100 mph top speed. Close to the Toyota spec of 103.
    Does the v come with the same size tires as the Liftbacks? If not the difference in tire size could account for some difference in the calculation.
  4. ETC(SS)
    6,537
    I didn't know about the difference in "gearing", and since the station wagon probably has about the same Cd as the more trim members of the G3 lineup, I suspect that it's electronically rather than drag limited.....so yeah.
    A little over a buck sounds right to me. :)
  5. ImeanGreen
    ImeanGreen Prius v Five BP Brigade #236
    547
    73
    Somewhere out there
    Here's a video of a regular prius topping 133 mph.
    Seems impossible but that's what the video shows and don't know the specifics.
  6. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    P205/60-16 on v2 and v3
  7. toyotechwv
    toyotechwv Toyota Technician
    474
    251
    Princeton, WV
    That's kilometers chief. Prius will do 116mph, personally verified. Haven't tried the wifes V......yet:cool:
    SPH-D710 ? 2
  8. ImeanGreen
    547
    73
    Somewhere out there
    Converting 215kph is 133mph. I haven't tried it on my V's yet and was just sharing a YouTube video. :)
  9. toyotechwv
    474
    251
    Princeton, WV
    It. Won't. Do. 133mph. Convert the speed in your video to mph and that's the speed it's doing. It takes a Prius nearly 11 seconds to reach 60, you really think one broke 130 that quick? Short answer, no.
    SPH-D710 ? 2
  10. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
  11. ImeanGreen
    547
    73
    Somewhere out there
    I don't think I am the right person to answer your question. Remember, this is not a US version Prius. You may need to ask the youtube account owner to verify it. I can't comment on things I don't have or done. I can only speculate. Read my post at the bottom "seems impossible".
  12. jdcollins5
    5,131
    1,338
    Wilmington, NC
    If I substitute the above tire size in the equation then the top speed calculation comes out to 102.25 mph. Even closer to the Toyota spec of 103 mph.
    I just chose a Michelin Energy Saver AS tire in the 250/60R16 size and used this tires Revs/Mile. Other OEM tires will vary in Revs/Mile and would change the calculation slightly.
  13. 13PV
    13PV Junior Member
    82
    2013 Prius v wagon
    introducing the new prius. 0 - 215km/h (top speed) in a whopping 1 minute at 50 seconds!
    maybe they were going downhill
  14. attyjeff
    attyjeff Member
    153
    40
    it looks like 120, look here
  15. jeep2prius
    jeep2prius Reformed Jeepster
    17
    Los Angeles
    Due to the potential of the California State Highway Patrol reviewing this site, I "plead the Fifth" and decline to comment. (But I-10 between Indio CA and Buckeye AZ is flat and smooth, and it's been rumored that a Prius was clocked at 105 mph in that area. Just saying....)
  16. That_Prius_Car
    That_Prius_Car Austin Kinser
    1,282
    344
    Pittsburgh, PA
    This is from the video game "Gran Turismo 5". :)
  17. GeeksDelight
    GeeksDelight Junior Member
    Vancouver, BC
  18. DomoDriver
    DomoDriver Junior Member
    28
    New Mexico
    You can't assume that. The GenIII Prius has a Cd of 0.25, and is the lowest Cd of any mass-produced car. The v has a Cd of 0.29. That alone may be enough to account for the 20% MPG hit you get with the v.
  19. rdgrimes
    rdgrimes Senior Member
    1,740
    446
    New Mexico, USA
    2018 Prius Prime
    The v has a different drive ratio, which is the main reason for lower MPG.
  20. DomoDriver
    28
    New Mexico
    I can see how both affect top speed, but how does the drive ratio affect MPG? Though higher frictional and pumping losses in a conventional car, but how in the Prius? We're always running the engine at its most efficient RPM for its load, so doesn't that compensate for the higher final drive ratio?
